Old February 20, 2010, 07:47 PM
AmuseMe's Avatar
Default Corsair HX750 Cable Lengths?
I am going to be buying some sleeving from Nils for a Corsair HX750 and am needing to know cable lengths. I can not seem to find it on there site, or any retailer for that matter... Does anyone know the lengths?
Old February 20, 2010, 08:52 PM
Something like this? This is for a HX850, I'm assuming the lengths are the same
Old February 20, 2010, 08:58 PM
AmuseMe's Avatar
If anything they will be a bit longer - which is good because it is always good to have more than less
Old February 20, 2010, 09:25 PM
lowfat's Avatar
I really wish companies would extend the 8pin CPU 12V cable. Every power supply I buy I end up cutting the cables and extending them.
1. Xeon ES 4c/8t * X79-UD3 * HD7970 * 16GB DDR3 * 64GB Crucial M4 * 80GB ioXtreme * 1000W Silverstone
2: 27" iMac * i5 750 * 80GB X25-M G2 * 4GB DDR3 *
3: 2600k * P8P67 Pro * GTX460 * 16GB DDR3 * 40GB X25-V * RR2314 * (2) Sans Digital TR8M-B * 46TB * 1050W Enermax
Old February 20, 2010, 11:28 PM
AmuseMe's Avatar
that's why I love revearse ATX and bottom
mounted PSUs
Old February 21, 2010, 07:50 AM
Fudd Rucker's Avatar
My 8 pin on my HX750 is pretty long, in my lancool im able to route the 8 pin around the back of mobo plate through the hole and half way down the board. All of the cabling is very long though.
Swiftech MCP-655 | EK Supreme Acryllic
XSPC 360 | DD Dual 5.25"
Primochill 1/2" Tubing | 3 x 38mm Kaze 3000rpm
EK Nickel GTX 480
Old February 21, 2010, 09:45 AM
AmuseMe's Avatar
That is good to know as I will be using a HX750 in a Lancool build
Bottom mount PSU cable lengths Bond007 Cases 6 November 23, 2009 12:36 PM
[FS] 2 Week Old Corsair HX750 ~140 + 1/2 Shipping! Mike_E Buy/Sell & Trade 9 September 1, 2009 11:52 AM
How much for a 2 week old HX750? Mike_E Off Topic 2 August 31, 2009 04:13 PM
Do hose lengths matter ? Shadowmeph Water Cooling 4 July 17, 2009 06:08 PM
Corsair HX750 for 155.99$ rapmaster Computer & Electronics Hot Deals 2 June 24, 2009 07:03 PM
