Old October 14, 2007, 03:02 PM
Babrbarossa's Avatar
Default 2 PSUs in a Stacker
Anyone here own a Stacker 830? I have one on the way and I'm wondering about the possibility of using both of my OCZ GXStream 700w PSUs in there- I have a watercooling setup and a ton of fans so I'd like to break the load up a bit - also I'm going to add a second loop if I get another 8800 which has been under consideration for some time ;-)- is there room for two loops, two PSUs?? also how much load to you need to put on them to get them to put out power?
I know it would be much simpler to get a 1KW PSU, but yasee, I have these two puppies here.....
psst, wanna see my binder?
Old October 15, 2007, 10:05 AM
Robscix's Avatar
You could sure, if you can fit them both in the stacker. You also need to come up with a scheme to get them both to power up at the same time. Use the power switch for the one and get another switch for the back up PSU. May be more trouble then it is worth -Cool no the less.
Old October 15, 2007, 07:24 PM
Theblackmages's Avatar
you could do it and hot wire em so they start at the same time, I wouldn't do it.the problem is that if you put power for only 12V rails you could do something that's called "Crossloading" and It will break the psu after a while.If you don't put power on the 5V rail and 3.3 at the same time well it does that.just get a bigger power supply and sell those two :P
Old October 15, 2007, 11:31 PM
the original stacker came with the wiring connector to run 2 power supplies.
Old October 15, 2007, 11:32 PM
heres a link to what it looks like.Dual PSU 24-Pin Adapter Cable Products Model: ULT40011 [ULT40011] : Performance-PCs.com, ... sleeve it and they will come
Old October 16, 2007, 12:33 AM
All that adapter is doing is splicing into a ground and the only green wire off the main power supply which is the wire that signals the power supply to turn on.
The issue with this is that as said if you don't apply enough load on the secondary power supply you could possibly burn it out.
Old October 16, 2007, 08:44 AM
Shadowmeph's Avatar
I am new at this and am wondering what is the purpose in having 2 power supplies? why not just have a very good single PSU wouldn't you save money that way
Old October 16, 2007, 08:55 AM
Robscix's Avatar
He already has the extra PSU laying around.
Old October 16, 2007, 11:09 AM
Sometimes you want as much power dedicated from one power to power your system and another to run accessories like water cooling pumps and fans and this helps in taking strain off one power supply and make it work better.
Old October 16, 2007, 02:38 PM
Hmm- any links to discussions on this underload burnout thing? I'll look into this more later tonight.
Stacker 830/832 log. lowfat Case Mods, Worklog & Gallery 25 January 26, 2008 01:12 PM
Stacker 810 vs Aurora 570 enaberif Cases 22 October 18, 2007 06:10 PM
PSUs: how much power do you really need? Babrbarossa Reviews & Articles from the Web 7 May 9, 2007 12:16 AM
105 PSUs reviewed! Babrbarossa Reviews & Articles from the Web 9 April 30, 2007 05:19 AM
Super Flower PSUs any good? Fielding Power Supplies 9 March 19, 2007 09:37 PM
