Originally Posted by ubernoobie I've got a ocz z series 550watt, so far it runs everything fine, cables a bit short but the really funny thing is, -12v is around -6.34v from hwmonitor, the +12 v stays rock solid @ 12.48 load or no load. Is the -12v lead to anything bad if it's not at -12v? Also It's VERY quiet and a deal if you got from ncix boxing day (30dollars mir) |
Just ignore the numbers you get from HWMonitor. They're wrong, so you don't have to worry about them reporting voltages that aren't in the right range. If you really want to test the PSU voltages, use a digital multimeter according to this guide:
http://www.bfgtech.com/bfgpower/troubleshooting.html
Anyway, that's a decent enough budget PSU if you get it for a cheap price. Wouldn't be my preference, but it does the job, and as long as you're happy, it's all good.
