Old January 31, 2010, 11:55 PM
MonsterSound's Avatar
Default OCZ Z-series 650w 80+ siliver; efficient but limited
I noted in the HardwareCanucks F@H Team / Energy Meters thread some power comparison measurements I took on my OCZ-Z series 650w 80+ Silver p/s and I thought I'd repost that here with a bit more info as there a definite limitations to this power supply (I should have started a thread rather than hijack in the 1st place ).
Pros: Efficient 80+ Silver (up to 88% advertised), quiet, low cost, 5 year warranty
Limitations: Short Cables, Low number of connectors
Only 1 short cable with 4 SATA connectors which restricts not only the number of devices connected, but also the devices must be close to each other.
Only 2 PCIe connectors (1 x 6 and 1 x 6+2); I kind of understand what might be OCZ's logic here in that if you SLI or Crossfire 2 cards that require more PCIe connectors, you probably should be looking at more than a 650w, but I don't quite buy it. What if I just want to add a physX card, or SLI 2 x 9800gtx's @ 140w each?
Summary: So far, I'm happy with the OCZ-Z 650 mainly because it is quite efficient, quiet, it currently fits my needs.
Low cost $64 (AR).
But, because of its limitations, it may not be suitable for many builders/cases.
Efficiency Comparison___________________________
originally from HardwareCanucks F@H Team / Energy Meters thread
I was curious about how much greater efficiency/savings (if at all) a newer 80+ PS would deliver, so I picked up an OCZ Z-Series 650w 80+ SILVER (advertised as up to 88%) and compared it to my older SilverStone ST60F - 600w (advertised as 75%).
Overall I was impressed and a quite surprised by the degree of difference, especially when idle or folding. I checked the folding results several times as that what the system is usually doing and the difference was dramatic. I expected less and suspect my ST60F may be less efficient than its specified 75%.
P.S. While measurements were repeated in all cases, the results are not scientific, …but interesting. I did make sure that the CPU was locked (stepping was off) and that GPU step down did occur during idle, Prime95 and Folding measurements.
Btw, PF with the ST60F was 98% and the OCZ-Z slightly less at 96%.
cheers
Here is a breakdown of the wall power readings in watts that I measured with a UPM EM130 (borrowed):
Code:
 my Heatware,  RFD &  eBay
MAIN: i7 860 @ 3.9Ghz wH50 / XFX 7970 BEDD / GA-P55-UD3R / 8gb G.Skill 1770 1T / ASUS 25.5" / NZXT-hush / XFX650 / Echo3g / 500gb Raid0 / Eclipse / G3-Lazer / YSM1 / z5300 / Win7 Pro64 / APC Xs1300
HTPC : nMedia6000B / AMD X2 4400+ / M2A-VM / Corsair 4GB 800 / LiteOn Blu-Ray / 8800GT / Samsung 46"LCD / 1.5TB / OCZ500 / ATI550 / nMedia Wrless Kbrd & Rmte / z-5500 / Win7Pro / APC700
"You must be the change you want to see in the world"
- Mahatma Gandhi
Old February 1, 2010, 12:07 AM
Zero oh Zero where are you !!!!
"What is the colour when black is burnt ?" - Neil Young
Old February 1, 2010, 12:31 AM
Oversized Rooster's Avatar
Nice write-up! I've been eyeing those new Z-Series for quite some time but was won over a special price on the Seasonic M12D instead. According to reviews I've seen, aside from the obvious high efficiency, these are truly excellent PSUs. (reminds of the time when OCZ blasted into the PSU market with the Powerstream series)
Main: Intel 2600K @ 4.8GHz | Gigabyte P67A-UD7-B3 | 16GB Corsair DDR3-2000 | 2x120GB OCZ Vertex 2 in RAID0 | 7x2TB WD Caviar Black | 3WARE 9650SE | Antec 1200 | Seasonic M12D 850W | 1.5GB GTX 580 | 2x27" Asus VE278Q | Auzentech Prelude | Win7 Pro 64-bit
Office: Intel 655K @ 4.4GHz | Gigabyte P55A-UD3 | 8GB G.Skill DDR3-1600 | 2x40GB in RAID0 Corsair Force | 640GB WD Caviar Black | Antec NSK4482B | Corsair Builder 500W | 1GB Radeon HD 6450 | 2x25.5" Asus VW266H | Win7 Pro 64-bit
Old February 1, 2010, 01:06 AM
sswilson's Avatar
How old is your Silverstone? Keep in mind that all PSUs will degrade over time, although those are some interesting results between the two.
ASUS SaberTooth 990FX / AMD 1090T / 2X4 Gig Gskill RJ X / XFX Pro 1000W PSU / 2X MSI 560GTX-Ti Twin Frozr II / Corsair F120 / WD 6401AALS
TT Lvl 10 GT / DDCPX-Pro / EK XT 240 Rad / 2X Scythe Ultra Kaze / EK Supreme HF / XSPC 250mm Res / Dell Ultrasharp 2209WA
Asus CH IV / Athlon II X2 250 / 4X2 Gig GSkill Pi PC3-12800 / 2X GTS 450 / PC P&C 750W Silencer / PA 120.2 /
MCR220-QP-Res / Swiftech MCP350 Pump / XSPC Laing DDC top / EK-Supreme HF / Lian-Li Pitstop T60 / Samsung 931BF
Old February 1, 2010, 01:11 AM
Originally Posted by Oversized Rooster View Post
...but was won over a special price on the Seasonic M12D instead. According to reviews I've seen, aside from the obvious high efficiency, these are truly excellent PSUs. (reminds of the time when OCZ blasted into the PSU market with the Powerstream series)
It's funny but the M12D is what got me looking for a more efficient p/s. I bought a M12D on NCIX's boxing day sale and was looking forward to testing it's 80+ Silver rating. Then due some unforeseen expenses (and slow NCIX delivery) I reluctantly chose to sell it and a few other things. But it stuck in my head that an 80+ Silver p/s should conserve energy and end up paying for itself, so for $64, I'd give it a try, even if it was OCZ. Previously I have had to RMA 3 OCZ StealthX and GamerX p/s's, as well as sell a 1000pro (with full loudness disclosure) because it was so loud, so I was hesitant.
My ST60F is ~2½ years old, version 4.
Code:
- Mahatma Gandhi
Old February 1, 2010, 09:46 AM
Default PSu
Efficiency is good for saving money on the electricity bill it does not effect or has to do with the performance of the supply.
When buying a PSU don't only look at the wattage the most important for performance are the number of channels (a powerful one for every voltage is preferred over multiple once)
The number of AMPS for each channel, the wattage delivery for each voltage Eg: 800W PSU /+3.3v 75W / +5v 80w / +12 645W/
The Ripple and distortion which are very important when overclocking to the max( the lower they are the better it is )
Finally the the components mainly the capacitors the best are Japanese once mainly Nippon-chemi con (NCC) OR Rubycon
For brands I recommend Antec,Corsair and Seasonic
Old February 1, 2010, 01:49 PM
Do I hear someone calling my name?
Actually, 650W is pretty much the sweet spot for a two-card Crossfire or SLI setup. The lack of PCI-E connector says one of two things to me: either OCZ was trying to save a few bucks by putting fewer cables on their PSUs, or they are not confident in the ability of their PSUs to power more high-end systems.
None of the Z-series units are what I'd call truly excellent. The 850W and 1000W models are pretty good, but they have disappointing voltage regulation and their DC output quality isn't all that impressive. As for the lower-wattage models, they are based on an improved version of FSP's Epsilon platform. They are efficient, but they are also group-regulated and are overall a pretty cheap design (hence the low price of these units). They're decent enough since FSP seems to have fixed the ripple issue with their original Epsilon platform, but they don't qualify as high-end PSUs.
Old February 1, 2010, 08:05 PM
Silvgearx's Avatar
great results, thanks for sharing!
Old February 2, 2010, 10:12 AM
I didn't say the 650W Z-series was a high end bracket PSU. Going to the high-end with PSUs pretty much implies 750W-1200W these days. You just don't get top end builds at the lower wattage ratings; not from the big PSU companies anyway.
So tell me Zero, what else about OCZ's stuff bothers you?
Old February 2, 2010, 11:22 AM
There are plenty of lower-wattage PSUs that I'd categorize as being excellent or very good quality. The lower-wattage Z series units are 'okay' at best.
The fact that they replaced the EliteXStream line with this crap?
OCZ Z-Series - Review Request? JD Power Supplies 14 December 20, 2009 12:01 PM
limited sale ssd a-data 500 series gingerbee Computer & Electronics Hot Deals 10 July 10, 2009 02:30 PM
8800GTS G92, TX750, NeoPower 650w, G Skill, OCZ werth Buy/Sell & Trade 18 November 25, 2008 08:56 AM
OCZ GameXStream 700W vs Mushkin 650W thatguy Power Supplies 4 October 7, 2008 08:48 PM
OCZ XTC series RAM mo' power RAM 16 April 2, 2007 09:54 PM
