Old January 7, 2010, 09:58 PM
odis172's Avatar
Default High load on a UPS
I bought a used apc SUA750RM1U, the batteries were apparently changed 6 months ago. The load lights are fluctuating between 3 and 4 out of 5. I used my wattmeter, and my system is drawing about 350 watts, the max wattage the ups can provide is 460W. The battery charge lights are blinking when I have my system drawing full power, but its not hitting 5 lights of load. I think the unit is saying that at the currant load, the runtime is below what the user has specified as the minimum runtime. I need to set the runtime alarm to low, 2 mins or so, but i cant because the powerchute software you have to pay for, and i didnt get the software with the unit. The battery does appear to be in pretty good shape, with a 220 watt load it lasted for a bit over 15 minutes.
In short... What can i do about this, is it safe to ignore the blinking lights?
Main Rig: Phenom II x3 720BE quad @ 3.2ghz - Gigabyte MA790GP-UD4H - 6 gigs ddr2 800 - EVGA GTX295 Co-op - Asus Xonar D2X - 2x 500GB wd raid 0 - PC P&C 750w - CM Stacker 830 Case - Samsung 24" - Logitech G15 keyboard - Logitech G9 mouse - Steelseries mousepad
Laptop: Lenovo T420 - Core i5 2520 - 8GB DDR3 - 500GB wd Black - BT3.0/Intel 6300 Wifi - 9 Cell
Server: E5200 - Asus P5Q Deluxe - 3 gigs ddr800 - 4x Samsung F3 1TB - Perc 6/i - 2 x WD Black 500GB raid 1 - Compucase RA448A00
Old January 8, 2010, 12:26 PM
The blinking lights on the unit just mean that it can't provide a lot of run time should the unit go in batteries with that load. The unit probably needs a calibration to straighten that out. Maybe when the batteries were last switched, they didn't calibrate the unit so it has the wrong info.
Charge the unit to full and then pull the plug, how much run time do you get? If you're happy with the results, don't worry about the blinking.
If you want to get rid of the blinking, you need to calibrate. Also, PowerChute basic is free.
Old January 8, 2010, 12:42 PM
odis172's Avatar
So i downloaded "PowerChute Business Edition v8.0.1 for Windows Vista/2008/2003/XP/2000" (was free) but during install it refuses to complete because "its not compatible with vmware server." This is pretty poor, since i dont actually run vmware that often. Guess ill just live with the blinking lights! Thanks tony
Old January 11, 2010, 11:12 AM
It shouldn't be giving you that kind of problem. Try and reinstall it again, maybe there was a problem. Also, you can always do a manual calibration if you're interested, let me know and I can walk you through it.
Tony
Q9550 + Hyper 212+ HSF = 76c full load... Too high? oblisk CPU's and Motherboards 11 October 29, 2009 11:18 PM
[FS] BNIB High End Radiator 240 TFC **High Performance** qaz393 Buy/Sell & Trade 4 August 17, 2009 02:47 PM
can't load an operating system help dubbaz Troubleshooting 5 February 3, 2009 06:42 PM
A decent, high power UPS? Iamcanadian7 Power Supplies 9 December 27, 2008 10:33 AM
My Computer takes 4 ever to load kcksteve Troubleshooting 13 October 16, 2007 04:50 PM
