View Poll Results: Sleeve the psu or buy extensions to sleeve?
Sleeve the psu directly 3 30.00%
Buy adapters and sleeve those 7 70.00%
Voters: 10. You may not vote on this poll
Old January 3, 2010, 02:11 PM
0o0 0o0 is offline
Default Poor man's mod: buy an extension to murdermod or sleeve the psu?
Hi guys, I was wondering if I should murdermod my tx750 directly, or buy extensions like these to murdermod:
http://ncix.com/products/?sku=15961&...facture=Others
NCIX.com - Buy nGear 4 Pin P4 Power to 8 Pin Epc Power Adapter Cable - NG-4P4M-8PEF In Canada.
NCIX.com - Buy Works 8 Pin Eps to 6+2 Pin PCI-E Power Adapter 8IN Cable Sleeved - CB-E8-P68F In Canada.
I'm not planning on upgradng anytime soon, but just in case it dies on me... but then again (I could be wrong), extensions aren't that great in a pc case
Let me know which path you guys recommend (keeping in mind I'm doing a poorman's mod with sleeving from fleabay and shrinkwrap from dealxtreme, and I've got a tx750 here), which one you guys did, and why. Thanks
Old January 3, 2010, 02:39 PM
Mattu's Avatar
If it is your first time sleeving, I suggest buying extensions and getting a feel for things - you don't want to break/damage your power supply.
I started off by buying some extensions, sleeving, and heat shrink off eBay. The extensions were poorly made but it turned out to be awesome because the pins came out really easily. A buddy of mine bought those n-gear ones from NCIX and ended up breaking a bunch of pins because they wouldn't come out of their hole (using both the staple technique and the sunbeam tool).
I bought this sleeving, and my buddy tired this and they both look great.
I just put in an order for 200 feet of neon green - comes to ~$30 after shipping to sleeve another power supply.
Anyway, good luck
Old January 3, 2010, 02:56 PM
0o0 0o0 is offline
Ha! same one I ordered last night! :high5: (if there were such a smiley)
No worries about me screwing up, I'm gonna try it on my mom's computer first. How's the carbon colour though?
Old January 3, 2010, 03:13 PM
Mattu's Avatar
Here is my computer after sleeving the extensions. I have a white LED strip in there
You can see through it but I like the effect
Old January 3, 2010, 03:21 PM
0o0 0o0 is offline
Thanks for the picture hmm I'll keep that in mind, gotta paint the wires and leave a tad bit coloured at the end for identification. I was gonna get a 932 too, and then the 922 came up during the refresh sale so I got that one, to save 40 bucks and I heard the 922 does better than 932 for air
Now I'm just gonna wait for that guy's sleeving and dealxtreme's shrink to arrive.. would this be worth making a worklog for? and sry thread was in wrong section
and one more question, should I interweave the wires? I've looked at a few pics and I've seen some of them weaving over each other, possibly to keep them together?
Old January 3, 2010, 03:30 PM
Mattu's Avatar
I actually have the ATCS 840
How are you going to paint the wires? They only good way i could think of is vinyl dye, although i've never tried it myself.
As for the worklog - thats up to you, there are a few on the internets but none on this site.
Old January 3, 2010, 03:36 PM
Mattu's Avatar
I wouldn't interweave them, i think it looks lame (unless you are making a rastafarian computer, then that would be awesome). If you like the look go for it, but i prefer them in a straight line.
Old January 3, 2010, 03:43 PM
0o0 0o0 is offline
uhh... I was just testing you guys...
oh I remember that stuff from art class 2 years ago! maybe I could go back and scavenge some of that stuff...
So here's my shopping cart: 800 grit sandpaper, black vinyl, black spray paint, primer... missing anything? Better chances at canadiantire or homedepot?
Old January 3, 2010, 04:08 PM
JD JD is offline
Canadian Tire in the car section.
And they have some Duplicolor Vinyl Dye which works very well on SATA cables (dyed my red ones black rather than buying new ones). Also dyed the god awful Noctua fans black. That didn't work as well since it scratched off around the screw holes after using them. I imagine it would be fine for the PSU cables too.
Old January 3, 2010, 04:55 PM
0o0 0o0 is offline
Ok, so canadian tire it is
Just wondering, does vinyl conduct electricity just as well as rubber/plastic?
Need some spare cash? Sleeve my PSU! Liu Kang Power Supplies 3 June 16, 2009 12:34 PM
[FS] How not to respond to a Mod while breaking a buy&sell rule Sniper Buy/Sell & Trade 8 January 20, 2009 06:32 AM
Sleeve my own cables or buy them pre-sleeved Cadence Peripherals 8 December 9, 2008 03:37 PM
ESata dual raid enclosure = poor man's hardware raid? sswilson Storage 10 May 6, 2008 10:58 AM
PSU fans - sleeve and horizontal? cegras Power Supplies 1 March 4, 2008 09:49 PM
