Old December 26, 2009, 09:44 AM
JD JD is offline
Default Quattro 850W - Upgrade?
I want to know if it's worthwhile for me to upgrade to probably another 850W unit, but from a different brand.
I have nearly the first revision of the Antec Quattro TruePower 850W, I think it's the one where they fixed the NVIDIA issues. It's not the current revision that's 80Plus Bronze with more amperage on the rails for sure. It also suffers from that high-pitched wine (which I know isn't a problem) from time-to-time depending on load of course. I also despise of the sleeving on it, those big clunky plastic things they used instead of heatshrink just make cable management that much more difficult. Otherwise it's been a solid PSU and also has stayed silent fan wise. I think I've had it for over a year now too.
However, I can feasibly fix the sleeving myself, maybe even do up some totally custom cables with only the connectors I need and in the right places. At the same time though, that'll probably end up around $100 to do (or more if I go the "MurderMod" route), in which case, maybe I should just get a newer 850W that has better cabling.
So far I'm looking at the Corsair HX850 or the Silverstone Strider Plus 850W. Both are solid units it seems, and the Silverstone is rather cheap considering it's performance and modularness.
I suppose I could drop down to a 750W, but I might as well keep the extra headroom I think. Planning on a 6-core, X58 (or newer), and at least a HD5870 (Fermi?) in the near future.
(I have money burning a hole in my pocket, thus why I'm considering this )
Old December 26, 2009, 09:50 AM
if dont dont realy want modular, the tx950w is 140$ after mir today at ncix.. if not i realy like the look of the xfx black ed 850w and form skymtl review it perform well and i think it's on sale for 170$ too
Old December 26, 2009, 09:52 AM
MarkOne's Avatar
I reach a point where I don't spent too much anymore, I wait also for see what happen with the 6 cores and the fermi, they have to many new thing now and to come. just take the Sata3, I'm sure Intel will came with a new chipset, so I don't spent for a x58 board now. I will suggest you buy the stick minimum of what you need for now, and keep your cash for next spring.
Old December 26, 2009, 11:10 AM
It's not worth it.
Old December 26, 2009, 11:37 AM
JD JD is offline
Definitely want modular, and I don't believe I need more wattage. As for the XFX, it performs well but the look of it just doesn't grab me. If it was blue instead of green, I would consider it.
Next spring? Don't you mean this spring? This summer, I'm overhauling my whole PC no matter what. I've had this X3350 + X38 board for too long
Originally Posted by Zero82z View Post
It's not worth it.
The logical side of me agrees, but the impulsive side says otherwise
Old December 26, 2009, 11:40 AM
In that case, it's totally worth it, and I'll be PMing you my address shortly so you know where to send the old PSU .
Old December 26, 2009, 03:09 PM
Raserei408's Avatar
You could upgrade to a 1000W or 1200W PSU and be set for a long time. HX1000 is pretty popular, but there's a BFG 1200W for not much more.
"If dancing is sure to result in failure then you must dance anyway."
Lo Mein said that, and I think he knows a little more about dancing than I do pal, because he invented it! Then he perfected it so that no man could best him in the club of honor.
Then he used his prize money to buy two of every whore on Earth. Then he herded them all onto a boat, then they all beat the crap out of every single one of him.
Old December 26, 2009, 03:14 PM
MarkOne's Avatar
this spring...
Old December 26, 2009, 03:35 PM
JD JD is offline
lol, I don't know about that
I'd probably sell it for a rather reasonable price though. I still have the box and all the cables too. The more I look at the HX850, the more I want it...
Old December 26, 2009, 03:45 PM
chrisk's Avatar
Folding Captain
That HX850 is awesome. Very efficient.
~$190 at Canada Computers:
Canada Computers - Power Supplies > Modular Gaming PSUs : Corsair HX Series CMPSU-850HX 850W ATX EPS12V Power Supply.
Fold for team #54196
Corsair HX 850w vs XFX 850w Black Edition BobbyLou Power Supplies 16 October 7, 2009 07:57 PM
Antec Quattro 850W 129.99 on NCIX Jackquelegs Computer & Electronics Hot Deals 0 April 24, 2008 08:23 PM
Antec Quattro 850W and 8800GTX Cptn Vortex Troubleshooting 12 March 11, 2008 08:49 PM
Bjorn 3D compares Dark Power PRO 850W and Thermaltake Toughpower 850W Babrbarossa Reviews & Articles from the Web 0 February 13, 2007 02:02 PM
