Old December 21, 2009, 03:55 PM
curtispan's Avatar
Default Would my 550w cut it?
Hi all,
I have a FSP 550w that runs these components:
E5200 overclocked (1.4v)
3 hard drives
6 fans
I will soon (hopefully) be buying a 4890 off of someone from the forums and was wondering if my psu will be able to run it. I don't think I'll overclock it since it will be sufficient for my gaming needs at stock.
Thanks
Old December 21, 2009, 04:16 PM
It should be enough. What are it's ratings for it's 12v line(s)?
Intel Core i7 920 4.1GHz w/ Thermalright U-120E
24GB G.Skill 1.25v DDR3-1600 9-9-9-24
eVGA 758 - A1
80GB Intel X25-M G2
1TB WD Black
1.5TB Seagate 7200.11 (still works!)
10.9TB RAID6 Samsung F4EG
XFX 5850 @ 1000/1250 w/ Scythe Setsugen
2X Dell U2412M Seasonic M12 850W
Old December 21, 2009, 04:17 PM
Yes, it's enough.
Old December 21, 2009, 04:26 PM
curtispan's Avatar
It's got 15A each on 4 12V lines.
Newegg.com - FSP Group FSP550-80GLC-R 550W ATX 2.01/ EPS12V SLI Certified CrossFire Ready Active PFC Power Supply - Power Supplies
Old December 21, 2009, 04:38 PM
To expand on my previous statement, it is enough, but you'd be better off with a higher-quality PSU.
Old December 21, 2009, 04:41 PM
curtispan's Avatar
Thanks, just making sure you guys knew everything needed.
Old December 21, 2009, 04:45 PM
geokilla's Avatar
FSP is a pretty good brand. I believe many name-brand PSUs use FSP as a basis or something like that.
@OP. Ya it's enough.
Old December 21, 2009, 04:47 PM
FSP's lower-wattage units are generally pretty decent. On the higher-wattage side of things, their products range from decent to outright bad. As for the OP's unit, it's a pretty cheap model, so although it's probably still decent, it's also nothing particularly great.
550W PSU to power a 4890? Caldezar Power Supplies 10 July 25, 2009 08:06 AM
Antec Tricool - Cut or not cut? Lol misterhelpmeplease Guides & How-to's 6 May 21, 2009 03:15 PM
Bfg gs-550 550w $40 3 of 7 Computer & Electronics Hot Deals 3 April 9, 2009 06:09 PM
Comment Thread for Gigabyte Odin GT 550W Review SKYMTL Power Supplies 4 July 16, 2007 09:24 AM
