Originally Posted by Caldezar Bottom mounts are more about cooling than anything else. With an intake vent at the bottom of the case, your PSU gets fresh air from outside the case and exhausts it out the back immediately. Rather than grabbing all the warm air from inside your case. |
I disagree, since if that were true every case with a bottom-mounted PSU would have vents on the bottom (which they don't, case in point Antec 900) and it would only be beneficial if PSUs had a a fan on the top or bottom, not on the front. Though this is also true, there's another reason that hasn't been addressed; a PSU is typically the heaviest component of a PC, and with it on the top, the case becomes top-heavy. Bottom-mounted PSUs make the case bottom-heavy and a fair bit more stable. Also, though this is case dependent, if a case has a bottom-mounted PSU it also has the potential for a top-mounted fan (either by the manufacturers placing one there or via modding).
Though this is considered to be the best location for a PSU (hence the industry shift toward bottom-mounted PSUs) there is a distinct disadvantage; cables may not be long enough to reach all the connectors, especially the ATX and CPU power connections. Unless the case is huge it's usually not an issue, and if worse comes to worse, there are always cable-extenders available.
