Old December 16, 2009, 07:57 PM
Default Power Supply Help/Advice
Hi,
Currently my system is:
Antec Earthwatts 430w
Asus P5Q-E
C2D e4300 (Soon Q6700)
BFG 8800GTS 320
4 x 1gb OCZ Platinum
2 x 320gb Sata Seagates
1 x 500gb IDE Seagate
I know I am probably going to have to upgrade as soon as I get my Q6700? What PSU would you suggest for this system without it being an overkill?
Thanks.
Old December 16, 2009, 08:10 PM
Soultribunal's Avatar
VX550 from Corsair or at most HX650.
If non Corsair is more your thing, a Thermaltake TR2 or TRX 650W should suffice for sure. ALways give yourself some headroom so your not running the Unit at max capacity.
Regards,
ST
The Below statement is True
The Above statement is False
Old December 17, 2009, 12:28 AM
You don't need to change your PSU. The 430W Earthwatts is plenty.
Old December 17, 2009, 06:34 AM
misterd's Avatar
Agreed. You're coming close if you're maxing both the video card + cpu at the same time. If you were going to upgrade your video card too then maybe I would consider it.
| i7 920 / Noctua NH-U12P / Asus Rampage 2 Extreme / Corsair Dominator XMS3 / Asus HD5870 / Corsair 600T / Corsair HX850 / Intel X25-M 80GB / Samsung DVD-RW |
| X2 5000+ Black Edition / Passive Scythe Ninja Mini / Gigabyte MA78GM-S2H
/ G.Skill Pi PC6400 2x2GB / Antec Fusion Black / Seasonic M12-II 500W / WD Green Power 500GB / Benq DQ60 |
#hardwarecanucks on irc.freenode.net
fiat justitia ruat caelum
Old December 17, 2009, 12:44 PM
Alright - thanks for the advice guys.
Old December 17, 2009, 01:03 PM
Arinoth's Avatar
Only reason to upgrade your PSU would be if you were to go SLI or put in a much higher end graphics card into the system, since you're only doing the processor you should be fine
Old December 17, 2009, 03:04 PM
I still would feel better with that Rig knowing at least 550W were behind it, espically if OC'ing it.
People underestimate how Power Hungry those GTS's are, Lemonlime knows first hand...
And that is a High POwer Consumption 65nm Quad Core...
Your Hardware, your Choice Ultimately but I wouldn't do it myself.
ST
[WTB] power supply 650+ power supply j-ronde Buy/Sell & Trade 1 March 31, 2009 10:45 AM
sub $100 power supply advice... Mumbly Power Supplies 0 March 5, 2008 04:55 PM
