Old November 28, 2009, 07:13 PM
MarkOne's Avatar
Default True PowerQuattro 1200w
Antec just annonce a new True PowerQuattro of 1200 watts
Google Translate
Old November 28, 2009, 08:21 PM
MpG's Avatar
MpG MpG is offline
Hopefully someone reputable gets this thing in for review - I want to see how well that powercache feature actually works.
Old November 28, 2009, 10:52 PM
JD JD is offline
Shame they still use that terrible sleeving method. Those massive black plastic things make cable management so much more difficult. Why oh why couldn't they just use normal heatshrink?
As for the PowerCache...
PowerCache™ is a technology that helps to stabilize the power output to CPU & video card. By adding a 2200µf capacitor at the end of the CPU and graphics cables, power can be delivered instantaneously where and when needed rather than from the power supply itself. For example, a 23A increase of demand from the CPU or GPU could cause a voltage drop of 1V causing a crash or reboot. With PowerCache™, the voltage drop will be just 0.2V, keeping the system running and stable.
Interesting concept, but it adds quite a bit of bulk to the CPU and PCIE cables.
Old November 29, 2009, 08:01 PM
MpG's Avatar
MpG MpG is offline
That's actually what I'd really like to see - a 2200uF (the unit they showcased awhile back said 3200uF?) capacitor small enough to actually fit inline like that.
Old November 29, 2009, 08:32 PM
JD JD is offline
Somewhat on the front of the box:
Via: Antec Quattro 1200 RoHS 1200W TruePower Quattro - 80 PLUS Products Model: TPQ1200 [TPQ1200] : Performance-PCs.com, ... sleeve it and they will come
Old November 30, 2009, 01:16 PM
EaGle1337's Avatar
The cap idea's a really great idea. any one see the jonnyguru where he put a cap on the beginning of the modular cable(i think it was the pci-e) on a BFG psu and it reduced the ripple?
Old December 3, 2009, 03:49 PM
MpG's Avatar
MpG MpG is offline
Hmm, I understand at least one known reviewers are getting this unit, but the graphs in this review don't look all that promising, actually.
But at least I can see how they pulled off the 2200uF inline cap thing - the caps are only rated for 16V.
Old December 3, 2009, 03:53 PM
Babrbarossa's Avatar
They're probably just further overstretching the guts of an 850- although full load on one of these things isn't a condition you're going to run under very much.
Main: ASUS P6TD Deluxe// i7 920// XFX HD 7970// 6GB GSkill Trident 2000// Corsair HX1000// Temjin TJ-07// OCZ Vertex2 240GB// GSkill Titan 256 SSD//Kingston SDnow 120GB// Logitech G9 //X-Fi Prelude//Merc Stealth//
Cooling: Coolit Boreas 12 MTEC// HK copper v.3//EK multi 150 res// Swiftech mcp355//EK nickel WB
Screen: Samsung 27" 850D
Old December 3, 2009, 04:36 PM
+3.3V voltage regulation wasn't great, but aside from that the PSU's performance was very good.
Not by a long shot. This unit uses a completely different platform from the older Truepower Quattro units.
Old December 3, 2009, 07:00 PM
MpG's Avatar
MpG MpG is offline
But some of the 12V rails drop over 0.3V, and the voltage ripple was nothing to write home about either, on any of the rails. Certainly doesn't seem like those extra caps are doing any miracles.
It's not that it's a failure by any means, maybe I'm just a little jaded by some of the other 1kW+ offerings that have hit the market recently. If I actually needed that kind of power, I'd like to know that the maker/designer used the technology available to provide the power properly. Silverstone's ST1500 that JG just reviewed only had a 0.09 drop under full load, despite handling 300W more. I suppose it's selling price will determine how good of a value this unit is.
Help me pick a new 1200W PSU zlojack Power Supplies 31 August 8, 2009 12:44 AM
FS: Silverstone Zeus 1200W zlojack Buy/Sell & Trade 10 November 16, 2008 10:05 PM
Silverstone Zeus 1200W Review Comment Thread SKYMTL Power Supplies 16 March 10, 2008 06:49 PM
Got a free stove outlet? the NZXT 1200W! Babrbarossa Press Releases & Tech News 11 May 28, 2007 08:03 PM
Koolance Liquid Cooled 1200W Power Supply SKYMTL Reviews & Articles from the Web 3 May 21, 2007 11:53 PM
