Old November 24, 2009, 07:34 PM
Default hot psu = dying?
Am in the process of closing down my aunts office(she is closing and got a good number of old computers and cables etc...)
She offered me to pick up anything.
Picked up a dell server and also a desktop.
When disassemble the pc I noticed the PSU is hot! the case is very cheap and I felt the heat seem to pass thru the thin casing.
I then open the case and noticed the computer is very clean, absolutly no dust(very suprise since she have that computer ON for the past 2 1/2 year. I think her uptime was 450 days.)
When I touch the psu physically it is quite warm, it is not to the point it will burn my finger. The case has close to none vent, there are 2 40mm (1 side 1 back case fan which I giggled when I saw it.)
Computer was 3 years old ish with the following parts.
Pentium D 3.0
1gb ddr ram
7300 LE nvidia
asus ??? mobo
antec true power 550watt(I am sure it's 500 - 550) and it's probably the old truepower
is that a sign of psu dying? I am planning to use it 24/7 in my room.. last thing I want is to have my room on fire
Old November 24, 2009, 07:46 PM
martin_metal_88's Avatar
old true power were having a problem withthe fan controller if my memories good. The fan was not running (running slow) until the PSU was reaching a certain temp and then run 100%. If the computer have decent airflow then, yes the PSU can beon the last day. If it's really a 500-550 these part would not pull more then like...220W so he is not supose to get warn. I think you should plug it with 1 fan let it run add another fan and blablabla to see if he get's hot or if it was only due to bad condition.
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old November 24, 2009, 08:13 PM
MarkOne's Avatar
when a dead psu fan is solder on the board of the psu, and I'm to leasy to unsolder it , I just run a regular fan wire outside the psu ( true the hole of the other wire ) and plug it on a molex . do not open the PSU if you have no back groung in electronic. the condenser discharge can kill you, even unplug . Just change that PSU , even if you only change the fan, the condensers are aging too.
WRT54GS Dying? geokilla Networking 13 October 4, 2009 02:45 PM
Dying 790i... Nuggits Troubleshooting 4 August 19, 2009 01:20 AM
Sounds like a dying mobo Arinoth Troubleshooting 3 July 20, 2009 06:54 PM
Hot summer days, hot computer problems. NightRain Air Cooling 17 July 6, 2009 10:11 AM
PSU fan dont spin. loud. hot heat hohohee Power Supplies 14 April 13, 2009 05:59 PM
