Old November 22, 2009, 02:14 PM
MarkOne's Avatar
Run away from that PSU,,,,,, post your budget...you will have some sugestions from nice members.
Old November 22, 2009, 02:25 PM
gingerbee's Avatar
markone's got some good advice
Old November 22, 2009, 02:33 PM
How good do you honestly think a $13 PSU will be? Get this instead: Newegg.com - CORSAIR CMPSU-400CX 400W ATX12V V2.2 80 PLUS Certified Compatible with Core i7 Power Supply - Power Supplies
Old November 22, 2009, 03:11 PM
kendallcschm's Avatar
$400 budget... yea.. i got to go real cheap.. i got a set of $20 speakers too
Old November 22, 2009, 03:19 PM
MpG's Avatar
MpG MpG is offline
You're definitely running an IDE DVD drive? And only one hard drive? Because that power supply only comes with one SATA power connector.
Also, are you sure you need 4GB of memory? Lower-powered systems, especially if you're not running Vista, are often just fine with only 2GB of memory, and you're blowing nearly 1/4 of your budget on memory right now.
Old November 22, 2009, 03:21 PM
the person requested alot of memory.. and they requested a powerful CPU.. they told me they need that stuff.. and they refuse to tell me what they are using it for...
Old November 22, 2009, 04:27 PM
MpG's Avatar
MpG MpG is offline
Well, that power supply's pretty much got zero expansion room, it specs say that it's using a design that's several years old, and you can probably flip a coin to see whether or not it's actually reliable at its rated capacity. If this person wants a powerful computer, that's fine. But it's going to cost him - he gets to choose whether he pays now or later. Even one of Antec's second tier PSU's would be an improvement that Logisys tin can.
Old November 22, 2009, 04:30 PM
Sushi Warrior's Avatar
ANYTHING is better than Logisys. I'd even take Raidmax or Rosewill over that.
You're half way through some post and you realize it's from some retard who types like he's got an array of dog dicks for fingers
Old November 22, 2009, 06:17 PM
Probably porn...
can this work? hohohee Off Topic 16 May 27, 2009 06:50 PM
Does this work? Infiniti Water Cooling 3 January 15, 2009 07:10 PM
Is this going to work? stingo99 New Builds 0 January 5, 2009 12:04 PM
Will This Work? stormkiller22 Troubleshooting 9 March 5, 2008 06:02 PM
Will this all work? Infiniti Water Cooling 11 January 8, 2008 10:50 PM
