Old October 28, 2009, 10:01 AM
lcdguy's Avatar
Default Accurate Usage
I am thinking of merging 2 computers in one mega box :) i did a calculation on the PSU i normally use (extreme outer vision) and was wondering how accurate it is.
Specs.
P5Q Pro
Intel E8400
8GB DDR2 PC-6400
9x 1TB WD Black
XFX 4890 XT
1x DVD-ROM
1x DVDRW
Dell Perc 5i
Corsair HX750
The calculator says around 545 Watts based on a capcitor aging of 20% and 100% peak load.
Did you carpe your diem ?
Old October 28, 2009, 01:59 PM
MpG's Avatar
MpG MpG is offline
BS. If you can pull anywhere near that much from the wall with that hardware, you've probably shorted something, and should grab either the power cord or a fire extinguisher. Yeah, you'll have a fairly high start-up current with those HDD's, but you'll never load the CPU and GPU before they're finished spinning up.
Old October 28, 2009, 02:01 PM
JD JD is offline
Doubt it will pull anywhere near 545W from the wall. My PC (with HD4850 mind you) and 22" LCD drew under 400W during OCCT PSU Test I believe.
Old October 28, 2009, 02:16 PM
MpG's Avatar
MpG MpG is offline
OCCT can make my computer pull about 550W from the wall (insofar as my UPS can('t) be trusted), but my CPU is at 4.5Ghz and I have a metric ****load of fans and pumps. Factoring in the rated efficiency of my PSU, it's pretty doubtful that my computer is actually pulling over 450W.
Old October 29, 2009, 04:59 PM
headsh0t's Avatar
The 20% capacitor aging probably addes over 100w. Try it without the aging and see how much. Actually I'll do it :) brb
Old October 29, 2009, 05:29 PM
headsh0t's Avatar
K well I put in everything you've listed and put "Overclock my CPU" to 4000MHz and 1.3v, added a soundblaster card(all models), I ddin't know what kinda slot Dell Perc uses so I put it as x1 PCI-e, I added 4 120mm fans and I still only got 515w with 20% capacitor aging and 429w with no capacitor aging. That seems normal to me?
Old October 29, 2009, 05:54 PM
lcdguy's Avatar
well considering i am typing this from a computer with 9 HDD now i think it's fine :). i'm running some benchmarks based on 8MB testing as this array is going to be used mostly for files in excess of 4GB each. Will post the results if you like.
Power Usage when Folding Chos3n HardwareCanucks F@H Team 21 October 30, 2009 11:23 PM
Mysterious CPU usage Bucklaz Troubleshooting 10 September 12, 2009 06:05 AM
pf usage under windows xp.. omgwtf O/S's, Drivers & General Software 5 April 4, 2009 12:23 PM
Accurate CPU temperatures? Below_Cost Overclocking, Tweaking and Benchmarking 8 February 6, 2008 03:17 PM
core usage question Jim CPU's and Motherboards 2 July 12, 2007 07:32 PM
