Old September 3, 2007, 10:41 PM
BALISTX's Avatar
Default Voltage and PSU monitoring software
What's some good PSU and voltage monitoring software?
Heatware
HWBOT
Old September 3, 2007, 11:02 PM
There isn't.
Its called a Multi-Meter
Old September 3, 2007, 11:08 PM
BALISTX's Avatar
I know about a multi-meter but I saw programs that monitors voltage and stuff.
What are the three programs showing besides the speed fan.
Heatware
HWBOT
Old September 3, 2007, 11:12 PM
Yes there is software out there that will "show" you voltages but they aren't usually very accurate.
Old September 3, 2007, 11:14 PM
BALISTX's Avatar
what's the program in the lower right in the pic?
Heatware
HWBOT
Old September 3, 2007, 11:47 PM
Lowest right is called Motherboard Monitor
Old September 4, 2007, 05:25 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Voltage monitoring programs are a complete joke. The closest I have seen to accurate is Gigabyte's Ptuner software but you need a Gigabyte Odin GT PSU to use it and even then it is off my a fair amount.
Old September 4, 2007, 10:01 PM
BALISTX's Avatar
I'll get a digital multimeter
Heatware
HWBOT
Old September 4, 2007, 10:18 PM
sswilson's Avatar
Just for posterities sake... the upper right hand looks like an older version of Sisoft Sandra, and I suspect the lower left is a bundled motherboard monitor.
Old September 5, 2007, 02:23 PM
I picked up a digital non contact thermometer today for 33 bucks... just wanted to try it on the computer parts and see how it compares with the monitoring software..... seems Ill probably get different results since I can't get to the cpu/gpu's themselves....
i2600k sandy bridge @ 3.4ghz/ 2x 8800 GTX KO ACS3 PCI-E 630MHZ 768MB 2.0GHZ SLI'd / Raptor 74GB / Antec 1200 Hundred Gaming Case / G.Skill Ripjaws ddr3 1600 cl 8-8-8-24 - 8gigs / evga z68 SLI MOBO / Samsung DVD+RW / Corsair ax850 PSU / 24" Samsung CinkMaster
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Swiftech Apogee GT Cpu block
Feser One Red Fluid
Over Voltage a35599 Overclocking, Tweaking and Benchmarking 6 February 26, 2008 10:21 PM
RAM vs Mhz for Multi-Monitoring Lyxtwing Video Cards 6 January 23, 2008 09:53 AM
temp. monitoring utilities and e2180 nikitos Overclocking, Tweaking and Benchmarking 18 January 15, 2008 02:12 PM
PC Monitoring chibi_man O/S's, Drivers & General Software 5 November 25, 2007 11:46 AM
What is Stock Voltage? mattydies Video Cards 10 October 19, 2007 09:01 PM
