Old October 13, 2009, 12:50 PM
Default Power Consumption Question
If I had a 750W power supply and my system only draws around 500W, the power supply only draws the 500W from the wall, correct? It wouldn't be using 750W all the time, just 500W?
Old October 13, 2009, 01:04 PM
Only uses what it needs.
"What is the colour when black is burnt ?" - Neil Young
Old October 13, 2009, 01:07 PM
Thanks johnny! Just making sure so I won't be wasting electricity if I upgrade my power supply.
Old October 13, 2009, 01:14 PM
Jake_HT's Avatar
Well at about 80% efficiency, if it needs 500w to the PC, it will actually be taking 600w from the wall... but yes it only uses what it needs.
http://jakeht.deviantart.com/
Old October 13, 2009, 01:25 PM
bissa's Avatar
I'm pretty sure you just mean W not kW, because if a computer is using 500kW there is something VERY wrong.
it will only draw requirement/efficiency as a decimal. so if you have a low efficiency PSU like 50-60 you will be using close to twice the needed power while if you have a high efficiency PSU like 85-95 that it will only consume a small amount more than your hardware.
Old October 13, 2009, 01:34 PM
Oops, yes, meant Watts. Fixed. Thanks for the replies.
Old October 13, 2009, 06:29 PM
rjbarker's Avatar
1kW = 1000W
1.2kW = 1200W
Amazing the PSU's that are now required in this day and age eh?!
Tri SLi "Procyon"
http://i30.photobucket.com/albums/c3...ant2/nice2.jpg
Evga 4.2 Ghz Club....
Tri SLi 580 MK11
http://i30.photobucket.com/albums/c3.../MK11Multi.jpg
Tri SLi 580 Vantage
http://i30.photobucket.com/albums/c3...ant2/60K-1.jpg
......Remember, keep your head up....and your stick on the ice
Old October 18, 2009, 04:39 AM
Lima's Avatar
Didn't know that bit about efficiancy and how it plays a role in power consumption. But... Is that extra 100w being wasted or lost?
Thanks guys.
Old October 18, 2009, 06:27 AM
Gellidius's Avatar
the 15% lost power in a 85% efficiency PSU is dumped as heat.
Jacques
Ego cogito, ergo deus non est.
Old October 18, 2009, 03:18 PM
Lima's Avatar
Aha! So it goes to a complete waste only half of the year.
PC Power Consumption Analysis MpG Reviews & Articles from the Web 29 June 11, 2009 05:23 PM
48xx Powerplay and idle power consumption? superj Video Cards 0 March 6, 2009 07:24 PM
Folding power consumption Alwaysrun HardwareCanucks F@H Team 10 February 23, 2009 06:15 AM
I DID IT!!!! Serious power consumption SKYMTL Power Supplies 10 February 16, 2008 07:16 PM
F@H vs. Power Consumption cujo HardwareCanucks F@H Team 14 August 8, 2007 08:32 AM
