Old October 13, 2009, 05:46 AM
Originally Posted by Zero82z View Post
The 5870 actually uses up to about 160W of power by itself: DirectX 11 in the Open: ATI Radeon HD 5870 Review (page 7) - X-bit labs
And that's under FurMark, so normal power consumption while gaming or folding will be lower.
So if i every wanted to go crazy !
And have 3 it will still run fine
Old October 13, 2009, 07:10 AM
Yep, it would be fine.
Old October 13, 2009, 10:24 AM
rjbarker's Avatar
^^ Provided you have enough PCI-E Power connectors of course.
Firestrike Extreme: 21.452
MARK 11: 32.530
Old October 13, 2009, 11:40 AM
Just looked and i have got 6x 6-8 Pins & 1x 8pin
Old October 13, 2009, 12:33 PM
bissa's Avatar
the one 8 pin is for the MoBo connection though. and I don't really know compared to other PSUs but compared to my old TX450W this thing is about 3-4 inches longer.
EDIT : and the 850W is consistent output, (alot of PSU makers mark their PSUs based on the peak they reach) it spikes to about 1KW so you would probably be fine for everything you are trying to run.
Strong like hummingbird, swift like oak.
I'm sorry july, I couldn't see you behind all that feruary.
Old October 22, 2009, 03:25 PM
Allright Thanks, yeah the max i will ever have is 2x 5870's.
Build Progress.
Brought...
Tick - Intel Core i7 920
Tick - EVGA X58 SLI LE Intel X58
Tick - Corsair 850W HX PSU
Tick - Corsair 12gb Ram 1666MHz
Tick - Corsair H50 Water Cooling
Tick - Corsair 800D Case
Tick - WD 1TB Hdd WD1001FALS
Tick - NZXT Sentry LX (Fan Controller)
Tick - Razer Diamondback, Mouse
Tick - Razer Lycosa, Keyboard
Tick - ATI 5870 Graphics Card x1
Need...
Untick - ATI 5870 Graphics Card x3
Untick - LG CH08LS10 Blu Ray
Old October 22, 2009, 04:05 PM
Sorry to hijack this thread but which PSU should I get the 850W Corsair or this one which is $200 off at NCIX NCIX.com - Buy Seasonic M12D 850W EPS12V 20/24PIN ATX Modular Power Supply Active PFC 80PLUS 8PIN PCI-E 120MM Fan - M12D-850W In Canada.
Old October 22, 2009, 06:18 PM
They're equally good. Unless you can find the Corsair for a cheaper price (which I doubt), go with that Seasonic. $150 CAD after rebate is a killer deal for it anyway.
  #19 (permalink)
Old October 22, 2009, 09:09 PM
Alright thanks I think I'll be getting it shortly
  #20 (permalink)
Old October 22, 2009, 09:29 PM
bissa's Avatar
the corsair is alot cleaner than the seasonic one and it is probably alot higher quality than the seasonic one too.
Corsair Professional HX850 850W Power Supply Review SKYMTL Power Supplies 23 January 31, 2010 02:04 PM
Corsair TX850 850W Power Supply Review Comment Thread SKYMTL Power Supplies 14 July 25, 2009 01:56 AM
Corsair® Launches Energy-Efficient High-Performance Modular 850W/750W Power Supplies cadaveca Press Releases & Tech News 12 May 27, 2009 05:12 PM
