Old August 22, 2007, 12:34 AM
Infiniti's Avatar
Question PSU requirement
what would be the min power requirement for this system:
EVGA Nforce 680I SLI LGA775 Conroe ATX DDR2 2PCI-E16 2PCI SATA2 RAID Sound GBLAN 1394 Motherboard
EVGA E-GEFORCE 8800GTX 575MHZ 768MB 1.8GHZ GDDR3 Dual DVI-I HDTV Out HDCP DIRECTX10 Video Card
Creative Labs Sound Blaster X-FI Xtreme Gamer 24BIT Sound Card 7.1 PCI Retail Box Bilingual
Intel Core 2 Duo E6750 Dual Core Processor LGA775 Conroe 2.66GHZ 1333FSB 4MB Retail
Swiftech H20-220 Apex Ultra Universal CPU Liquid Cooling Kit
Corsair XMS2 TWIN2X2048-6400 2GB 2X1GB PC2-6400 DDR2-800 240PIN Dimm Dual Channel Memoryx2
Antec P182 Atx Black Mid Tower Case
Samsung SH-S203B Black SATA DVD+RW
thx in advance
Old August 22, 2007, 04:23 AM
8800GTX card require alot of juice. You'll at least need a deicated rail just for it. Most modern decent power supplies have 1 sometimes 2 (for SLI setups).
The power supply I got is fairly good. A silverstone Strider 600W. Just don't grab something too small on the real cheap. 400W or under. Strain a powersupply and next thing ya know you're getitn' a new one...if you're that lucky. sometimes they can take down other hardware with them.
The more wattage the more heat keep that in mind. Somethin' around $100-125 at NCIX is what you should aim for at least, the Power supply page isn't loading for me right now so...i can't go see. Just check out the top 10 on the ATX 12V page that should give you some idea.
that's gonna be a really nice gaming rig BTW.
3800X2@2.2GHz--2gb PC3200--200Gb Maxtor SATA2--eVga 8800GTS 320mb--eVga nForce4 SLI mobo--Klipsch 4.1--Antec nine hundred case w/Vantec 120mm on side--Vista Premium 64bit
Join our Folding@Home team!
Old August 22, 2007, 04:47 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
What exactly are you looking for?
Something modular? Or you don't care...
Also, what is your budget?
