Old August 19, 2007, 01:52 PM
Unhappy Min Psu requirements
hi guys i need a good and cheap psu for the next rig:
Memory
Corsair XMS2 2GB (2x1GB) DDR2 800 (PC2-6400) Dual Channel Memory TWIN2X2048-6400C4, 240-Pin, SLI Certified 119$
Motherboard
Gigabyte GA-P35C-DS3R LGA775 169$
Cpu cooler
Cooler Master Hyper TX 2 CPU Cooler 25$
Cpu
Intel Core 2 Quad Q6600 283$
Case
Nzxt Apollo Silver
Case Fan
Thermaltake Combo Cool DIY Series Silent Cat Fan 10$ Part
PSU
Black Ultra X-Finity 500W Computer Power Supply 40$
PCI_-E Vga
eVGA GeForce 8800GTS PCI-E Video Card 640 373$
Dvd Burner
Asus 18blt
is this psu good enough or i should by something better, i low on budget and heard good reviews about this 1 but is this enough (i want i the future to do a small oc max 2.66 mhz)...:help:
Old August 19, 2007, 02:39 PM
sswilson's Avatar
I'm starting to think that a good rule of thumb is to spend at least as much on your PSU as you do on your memory........
I wouldn't put a sub-$100 PSU into anything current unless it was an HTPC with onboard vid.
Old August 19, 2007, 02:48 PM
ok so what do u recommend? i heard enermax librety 400w is a good choice, something cheap max 75$...
Old August 19, 2007, 02:50 PM
b1lk1's Avatar
I'd recommend spending less on a CPU and more on a power supply. Anything under $75 is not worth putting in a PC since it will surely die fast from being overworked. One important thing to remember. When your power supply blows, it will almost definitely take out half your PC with it.
Driving sim: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 290X 4GB/128GB SSD+750GB HDD
Daily: Intel DQ67SW/i7 2600/8GB DDR3/WD 150GB VR+2TB HDD/CU II R9 270 2GB/Xonar D1
Old August 19, 2007, 02:52 PM
ok so what is your recommendation?
Old August 19, 2007, 02:54 PM
once again i need the minimal best as we say...
Old August 19, 2007, 03:00 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
You have a good system there. Why do you want to cheap out on the PSU?
I would not trust that Ultra on a system like you have there. Not at all. The MINIMUM and I mean BARE MINIMUM you are looking at is a good 500W power supply and if you overclock your quad above 3.5Ghz, you will need to look at something in the 550-600W range. I am refering to QUALITY PSUs here.
Something like...
Silverstone ST50EF
Corsair HX520
Antec Earthwatts 500W
IMO, maybe you should buy the Sonata III with the included 500W Earthwatts.
Old August 19, 2007, 05:56 PM
b1lk1's Avatar
Silverstone ST50EF has been flawless for me and I can definitely highly recommend it and it is somewhat cheap if you find it on sale.
Old August 20, 2007, 01:08 AM
what about enermax librety 400w i heard its a good 1 too...
Old August 20, 2007, 01:11 AM
and what about this 1
Antec TruePower Trio 550W
Question about power requirements (specifically HD2600 Pro) Kev Vikanova Video Cards 2 November 27, 2007 10:35 PM
Power Supply Requirements enaberif Power Supplies 9 August 1, 2007 02:22 PM
Power Requirements enaberif Power Supplies 6 July 10, 2007 06:20 AM
