/** * vBulletin 3.8.6 CSS * Style: 'FH_Canada'; Style ID: 11 */ @import url("clientscript/vbulletin_css/style-d37fcf9b-00011.css"); Min Psu requirements - Page 2 - Hardware Canucks
Old August 20, 2007, 05:14 AM
Dus Dus is offline
Save yourself some money from your motherboard. Instead of getting Gigabyte GA-P35C-DS3R LGA775 169$m, get this one instead Gigabyte GA-P35-DS3R for $137.69. The difference is the DDR2/DDR3. Are you actually going to upgrade your RAM from DDR2 to DDR3 without replacing the mobo/CPU combo in the future? I doubt it.
Take that extra $21 and invest into one of the PSUs SKYMTL suggested.
Old August 20, 2007, 05:32 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
And avoid Enermax. Their RMA service in Canada is absolutely abysmal.
Old August 20, 2007, 07:13 AM
b1lk1's Avatar
Originally Posted by DarkLloth View Post
what about enermax librety 400w i heard its a good 1 too...
I wouldn't run under a 500W PSU nowadays. You'll run out of power fast with something that small.
DAILY: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 270 2GB/128GB SSD+750GB HDD+2TB HDD
Old August 20, 2007, 09:15 AM
Amon's Avatar
Using a power supply rated beneath 500 watts is a moot point when you're spending that amount of money on memory, CPU, and CPU cooler to overclock your system--which, in turn, draws more power.
Question about power requirements (specifically HD2600 Pro) Kev Vikanova Video Cards 2 November 27, 2007 10:35 PM
Power Supply Requirements enaberif Power Supplies 9 August 1, 2007 02:22 PM
Power Requirements enaberif Power Supplies 6 July 10, 2007 06:20 AM
