before you power it up, open it up and take a look, the batteries are, "sealed lead acid" so they shouldn't leak but they sometimes do around the posts...
if you have a voltmeter check to see if they still have a bit of a charge in them, a 600va APC probably has 2 x 12v 7ah batteries wired for 24v... if you still have a decent voltage in them they might still be good enough to run the unit well,, if they are almost dead flat you will probably have to replace them.
I think a new set is about $50
so if you don't have a voltmeter but everything looks good inside, you could try and power it up, if no errors then let it charge up, once charged hook a lamp to it for a load and see how long it lasts for..
if my memory is correct there are about 6 Phillips head screws at the back side you take them all out and the UPS opens on a hinge towards the front of the ups.. so just pull up on the top part and the rear of the ups.
be careful, if the the batteries still have a decent charge that means the UPS can still make 110v so even if its not plugged in you could give yourself a bad shock..
