Originally Posted by odis172 Antec, i wont use. I used to work for Pc Medic, in atlantic Canada, and they used antec exclusively. The number of bad psu units I saw, i believe is higher then what really should be. It was quite common to have a 2-3 year old machine come in for service, and completely unrelated, the psu would be making a barely noticable high pitched squeel. The PSU would be working, but that alone qualifies it for an rma, so id swap it out, heck i wouldnt used any psu that sounds like that. ? |
Old Antec Truepower and Truepower 2.0 PSUs used low-quality capacitors that didn't respond well to heat and would fail prematurely. That has not been an issue for years and Antec makes some of the best consumer-grade PSUs you can find anywhere.
Originally Posted by odis172 The other problem may not be exclusive to antec, but about twice a month, a system would come in with blown psu, dead motherboard, dead HD, and bad cpu fan. (One customer had a 3yr old comp, with raid 1 - he wasnt too happy with the diagnosis ) Sometimes the customer reported the system to be used with a good power surge bar, sometimes not. Now i believe this is the result of a power surge, psu blows, and takes out several components. Mind you the power in some areas of Halifax is known to be terrible. Any thoughts? |
Not a PSU problem. A surge protector will protect a PSU from some surges, but not from dirty power, which you need a line conditioner or line-interactive UPS for.
