Old August 25, 2009, 12:23 PM
cb2222's Avatar
Default Advice Needed: Best Budget PSU?
Any thoughts on a budget PSU? I'm thinking $65 and under? It's just for a desktop PC that is in my living/dining room area. I was hoping to get something reasonably quiet but I guess beggars can't be choosers...any thoughts?
Cheers!
Old August 25, 2009, 12:24 PM
CMetaphor's Avatar
Quadfather
NCIX.com - Buy Corsair VX450 450W ATX 12V 33A 24PIN ATX Power Supply Active PFC 120MM Fan - CMPSU-450VX In Canada.
59.99 after MIR ?
Old August 25, 2009, 12:34 PM
I second this choice. Excellent PSU for an excellent price...
Current Rig: C2D E6400 @ 3.0GHz, Vendetta II, BFG 8800 GT, OCZ PC6400 8GB, HX520W, 2x WD 500GB HD, Segate 160GB, WD 200 GB HD, Lancool PC-K62, Windows 7 64 bit, Snow Leopard (on the way)
EVGA 680i SLI Motherboard $80 + Qualitas 73GB 10k SCSI $30
Old August 25, 2009, 12:54 PM
martin_metal_88's Avatar
+1 at this price exept in a awesome sale you can't get better, corsair are some of the est PSU ever made so.
Old August 25, 2009, 01:25 PM
JD JD is offline
$82 isn't budget (no I don't count MIRs).
Solid budget PSU would be something like this: NCIX.com - Buy Seasonic SS-350ET 350W ATX12V 20/24PIN ATX Power Supply Active PFC 80PLUS 120MM Fan OEM - SS-350ET In Canada.
Though depends on what kind of system this has to power...
Old August 25, 2009, 10:46 PM
What are the system specs?
Old August 28, 2009, 06:14 PM
I bought one of those for my friend. It's amazing how quiet it was. I bought it on directcanada.com but they dont have anymore in stock. I found this one on newegg for the same price. like I said, it was very quiet and pc power & cooling is a very good brand.
Newegg.ca - PC Power & Cooling Silencer PPCS420X 420W ATX12V 80 PLUS Certified Active PFC Power Supply - Power Supplies
for $50.99
Old August 28, 2009, 07:04 PM
MpG's Avatar
MpG MpG is offline
Nothing wrong with this guy either:
Corsair CMPSU-400CX 400CX 400W ATX 12V 30A Power Supply Active PFC 120MM Fan - DirectCanada
Advice Needed for Budget Minded, Casual Gamer cb2222 New Builds 12 July 19, 2009 03:27 PM
Trading Computer on a budget, Help needed 'puternewb New Builds 17 January 27, 2009 06:14 PM
Some advice needed please! D4ng3r Cases 5 December 9, 2008 12:45 PM
Advice needed on WC Jackquelegs Water Cooling 36 November 22, 2008 11:40 PM
Budget video card advice needed please. Mumbly Video Cards 9 January 17, 2008 05:59 AM
