Old August 25, 2009, 09:23 AM
Default what 120mm replacement fan for a Mios 545W PS ?
Hello guys , my 1st post on here and I have told my youngest son about this site as well since he likes to build and modify his own PC's so I expect he will join up .
Had the fan in my 545W Mios power supply hit the crapper ( bearing/noise/laboring ) and want to replace the 120mm fan . It's 12V of course but I'm wondering what CFM range I should be looking at to move enough air . PC doesn't get overworked so I doubt in the PS is doing much more than idling most of the time . The Mios 545W replaced the original PS which blew a couple years ago and was only a 350W .
Thanks !!
Old August 25, 2009, 09:36 AM
CMetaphor's Avatar
Quadfather
Hi and welcome to the forum!
Just about any silent case fan will do for a power supply. there's no need for a high-cfm and/or high static pressure fan in these situations. Beyond that is up to your preference. Some people will suggest using a Noctua fan, but i find they look like dead fish... lol. It's really up to you.
Old August 25, 2009, 01:28 PM
JD JD is offline
Personally I'd suggest buying a new, high quality PSU instead. I've never heard of this brand and if the fan died, there could be other faults with it.
Old August 25, 2009, 02:55 PM
Jackquelegs's Avatar
I'm going to agree with jdrom, a new PSU would be worth the trouble.
Iapetos
Zephyranthes
Old August 25, 2009, 05:01 PM
Lightbulb
Thanks !!
That power supply is aound $35cdn give or take a couple $
Do yourself a big favour Buy a new brand name quality power supply.
Cambridge,ON
MSI Z77 M Power/Bios17.12
3770K@4.5ghz
Mushkin #997007
Noctua NH-D14
Gigabyte GTX 660
Seasonic X-660
Corsair 540 Cube
Noctua case fans
Intel SSD
Win 10 Pro x64
Old August 25, 2009, 09:55 PM
MpG's Avatar
MpG MpG is offline
I'd vote for the new PSU as well, but if that's not in the budget, this first thing you'd want to look at is the original fan. There should be a label somewhere with a model number that can be cross-referenced to get an idea of what the manufacturer thought was needed. You'd be surprised at how strong some older PSU fans are, simply because their efficiency was so bad, and heatsinks so flimsy, that they actually needed something pretty powerful to keep temps down.
Old August 25, 2009, 10:49 PM
lowfat's Avatar
Could always grab a cheap Yate Loon and throw it in. Chances are it will work fine even w/ a low speed fan.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old August 25, 2009, 10:58 PM
Got an S-Flex 63CFM today and installed it....works great .
Yes I could go out and get a high end PSU but we arn't talking a high end PC here guys , it's my 6 year old Gateway pentium 4 beater .
The Mios 545W PSU is a low end unit , no hell but built better than a lot of crappers out there so I felt it was worth the fan .
Old August 26, 2009, 04:07 AM
You could have bought a high quality psu as the first component of a new build!
Old August 26, 2009, 06:07 AM
If I put any up grades into one of my PC's it will be my XPS 435mt , the old Gateway is just for regular use . The only mod it has had is a GeForce 7300GT my youngest son put in it for some games and this MIOS 545W psu .
With both my sons in the military you can imagine they like to play a number of military theme games but my youngest and his wife now live in Edmonton .
Broken 120mm fan 486 Off Topic 1 July 1, 2009 09:27 AM
[WTB] 120mm fans and fan grills kyle_L Buy/Sell & Trade 4 January 21, 2009 10:10 PM
New PSU and Fan replacement serenity Power Supplies 9 September 22, 2008 01:32 AM
FS: fan hDD cage w/ 120mm lighted fan, cpu funnel, pentium 1 elninio Buy/Sell & Trade 7 June 20, 2008 12:18 PM
120mm Fan Suggestions CMetaphor Air Cooling 16 April 14, 2008 08:16 PM
