Old August 22, 2009, 09:29 AM
Default Enough Juice?
I'm thinking of throwing in another HD4890 (see sig) to run Crossfire. Just wondering if current (no pun intended) 620W PSU -again, see sig- can handle the two cards plus a couple of 7200RPM SATA drives and the usual peripherals. PSU Calc shows roughly a max of 425W taking overclock into account. I'm not sure if the 'crossfire' designation implies a single x-fire card or two physical cards.
Thoughts?
[edit] Oops! Just discovered the HX620 I have only has 2 6-pin PCI-e plugs. Need 4 for x-fire. So based on that I may need to bump up to HX750 or HX850.
System Spec Peripherals: NZXT Kraken X42 CPU cooler | Zalman MFC3 fan controller | Steelseries Apex M800 kb | Steelseries Sensei mouse | Logitech Z-2300 2.1 speakersDrobo FS 6.5TB Synology DS1515+ 15TB
Laptops: Asus G74SX-DH71 | Asus G752VY
Surface Pro 4 Core i7/256GB
Old August 22, 2009, 04:57 PM
DrPepper's Avatar
You'd be on the edge with a 620W. I'd suggest you to go with the 850 on the safe side considering you will overclock your GPU.
Old August 22, 2009, 07:19 PM
Cheers, Dr. P! Already making the plans for an 850.
Old August 22, 2009, 08:20 PM
lowfat's Avatar
620W will be perfectly fine.
Mael
Big Lian Li
Forever Alone
Old August 22, 2009, 10:52 PM
Wattage *may* be okay but considering the two cards require 4 PCIe 6-pin connectors then no it will not be perfectly fine.
Old August 22, 2009, 11:12 PM
JD JD is offline
Well you could use molex to PCIe adapters. Not ideal though, but doable.
Though the HX750/850 are simply awesome modular PSUs and if you can afford one, then go for it.
Old August 23, 2009, 03:11 AM
burebista's Avatar
You need 2 PCI-E adapters otherwise HX620 is plenty for your future setup.
Old August 23, 2009, 09:17 AM
Originally Posted by burebista View Post
You need 2 PCI-E adapters....
Erm...no. A single HD4890 card requires 2 PCIe 6-pin plugs. Simple math dictates I will need a PSU w/ four 6-pin plugs.
Old August 23, 2009, 09:21 AM
element291's Avatar
then 4 pci-e adapters :P
| ASUS P8Z68-VPRO | Intel i5 2500K | 8Gb Patriot Viper Xtreme | 2x 60gb OCZ Solid 3 SSD | EVGA GTX260 Core216 |
Old August 23, 2009, 09:22 AM
Infiniti's Avatar
I'm pretty sure he means molex adapters, not the actual plug on the PSU itself. That 620W is plenty.
Am I going to have enough juice for tri-SLI? zlojack Power Supplies 10 January 8, 2009 12:05 AM
