Originally Posted by SKYMTL Check the voltages at the connectors with a DMM when your computer is under load. See what you come up with. |
I could do this but I would have to make up some junction connectors so I could tap into with my DMM. I did notice an increase in the voltages from the readings in the bios but not much. I never wrote them down and it was only 0.1 or 0.2 on the 12V.
So i'm guessing that recording the voltages with a program like asus probe wouldn't work? If so please post some software I could use to test my PC with. I'm a big noobe and I only overclocked the CPU because it was a setting in my bios to overclock by 10%. Also does a CPU start to run hotter over time(6 months)?
