Old August 14, 2009, 12:10 PM
zlojack's Avatar
Default No Rail Switch on Zeus ZM1200?
I just recently picked up this PSU and one of the great things about it is supposedly the ability to switch it to single rail if I so desire, so I tried to do this and, lo and behold, there is no switch in the little hole in the side of the psu (the one covered by the "Warranty Void if Broken" sticker )
WTF is up with that?
Am I missing something?
Old August 14, 2009, 03:15 PM
Perineum's Avatar
I believe you're just missing that little switch......
Old August 14, 2009, 03:19 PM
jtf2's Avatar
Silverstone Zeus ZU1200M 1200W Review
perhaps this is of some help.
shows a pic of where the switch is
Old August 14, 2009, 09:08 PM
zlojack's Avatar
I know where the switch is, but there's just a blank piece of black plastic in there.
Old August 14, 2009, 09:11 PM
jtf2's Avatar
hi jack.wherever it was purchased from should replace it then.
have you taken the cover completely off?
maybe it is a never revision and in their wisdom?,moved it elsewhere
Old August 14, 2009, 09:35 PM
Chilly's Avatar
Take a picture, apparently some of the revisions of the ZM1200M have the switch off center from the hole. I know mine did, took a flashlight and a bit of fiddling to find and switch the switch via the small hole.
Old August 14, 2009, 09:36 PM
One word - CORSAIR !!!!
Old August 14, 2009, 09:41 PM
Chilly's Avatar
The ZM1200M is a superior PSU, better ripple regulation, single rail, and etc. Corsair sells good, solid PSU's, but they aren't the best.
Old August 14, 2009, 09:45 PM
But where's the switch ? Oh yeah that's right, it might be a little off where the hole is. Geez I wonder how that could have been missed.
Old August 14, 2009, 10:08 PM
Chilly's Avatar
So they screwed up on the casing aliment, thats like saying my system, Chaos 1.0 sucks, has horrible performance and the components are of crappy quality because it's not in a proper case, the motherboard is half sticking out of said case and its hard to add and remove expansion cards.
Just because they messed up with the casing/box doesn't change quality of the important stuff, the actual components on the inside.
FS: Silverstone Zeus 1200W zlojack Buy/Sell & Trade 10 November 16, 2008 10:05 PM
Zeus zm1200m maurier Power Supplies 3 August 11, 2008 05:57 AM
Silverstone Zeus 750W Mulder Power Supplies 14 June 25, 2008 09:49 PM
Single vs Multi rail PSU's durdy Power Supplies 1 December 30, 2007 09:16 AM
-12v Rail and Poor Performance kcksteve Troubleshooting 11 September 9, 2007 08:08 PM
