Old August 14, 2009, 10:08 PM
zlojack's Avatar
Originally Posted by crazyhorsejohnny View Post
One word - CORSAIR !!!!
I've already got one, thanks.
Anyway, I'm loath to remove the cover, but I think I'll have to see what Silverstone says. I've sent an email to them.
I started sleeving the cables like a bonehead, so of course I wouldn't be able to return a complete unit. I didn't even think to check for the switch until later.
Old August 14, 2009, 10:20 PM
Chilly's Avatar
ZOJACK!! Posting this from the MacBook Pro, I just checked mine, the switch it UNDER the black plastic, towards the back(modular connections end), I completely forgot I had to move the black plastic out of the way to get to my switch!
Old August 14, 2009, 10:26 PM
zlojack's Avatar
Thanks, Chilly!
You saved me a lot of headaches.
Old August 14, 2009, 11:23 PM
Originally Posted by Chilly View Post
The ZM1200M is a superior PSU, better ripple regulation, single rail, and etc. Corsair sells good, solid PSU's, but they aren't the best.
Corsair HX750/850 has better voltage regulation, less ripple, single rail (not that the number of rails matters). It's just not enough watts if you need that many.
Old August 15, 2009, 12:05 AM
Chilly's Avatar
I was referring to the HX1000, as its the CLOSEST unit Corsair has to the ZM1200M.
The +3.3 and +5 rail on the HX750/850 are *slightly* ripple better(35mV ripple on the +5 line vs the 10mV) but the 12v on the ZM1200M is CLEAN BABY CLEAN.
Not too much is different about the numbers here. We get the same amazing efficiency results, which is likely due in no small part to the high 12V voltage readings, similar better than 2% regulation numbers, and the unit is having no trouble taking the heat. I likes what I sees.
the 12V output is so clean this unit is almost like the second coming of the Antec Signature SG-850. Only, the Signature wasn't this powerful. Hubba hubba!
Silverstone Zeus ZM1200M 1200W Review
Corsair HX850 850W Review
Corsair sells some good and great PSU's, I never argued against that, and the HX750/850 are some great ones, that in pure statistics trade blows with the best of the best. Even so, the HX750/850 are brand new and comparing a 750/850Watt unit to a 1200Watt unit(450/350 Watt difference!) is like comparing Apples to Oranges.
Old August 15, 2009, 01:47 AM
Chilly's Avatar
Originally Posted by zlojack View Post
Thanks, Chilly!
Your welcome, I was reading over your posts again, and I was like "black plastic... sounds familiar"
Old August 15, 2009, 09:41 AM
zlojack's Avatar
Well, doesn't seem to be what Chilly said. Still no access to the switch.
EDIT: Done. I opened it up and the plastic protector didn't have a hole for the switch, so I made one with a cutter.
Even though it says it will void the warranty, should anything happen, I'll fight it to the finish.
Anyway, it's a single-rail PSU now.
Time for more sleeving.
Old August 15, 2009, 10:02 AM
Chilly's Avatar
Cut the black plastic? I don't remember what I did to get the plastic out of the way on mine but I do remember having to move it. As for warranty, I hear that SS have pretty decent/understanding RMA dept.
Glad to hear you got it working in the end, now don't screw up the sleaving and kill the PSU!
  #19 (permalink)
Old August 15, 2009, 10:04 AM
zlojack's Avatar
Yeah, no kidding!
I hope they are understanding when they put out a PSU that has a screwup like that!
There's a plastic shield on the inside of the metal casing that had no hole in it for the rail switch. I cut a hole in that for easy future access to the switch (though I doubt I'll be needing to touch it again)
  #20 (permalink)
Old August 18, 2009, 03:51 AM
Jackquelegs's Avatar
I always wanted a Zeus, but never had the cash to buy it.
What an oversight on Silverstone's part, is it actually a warranted use of the PSU?
On another note regarding the Corsair PSUs. I as well respect their performance, but I would never buy one . There's something about them that I don't like, maybe it's just the massive hype over it. I'm an Enermax guy for now
Iapetos
Zephyranthes
FS: Silverstone Zeus 1200W zlojack Buy/Sell & Trade 10 November 16, 2008 10:05 PM
Zeus zm1200m maurier Power Supplies 3 August 11, 2008 05:57 AM
Silverstone Zeus 750W Mulder Power Supplies 14 June 25, 2008 09:49 PM
Single vs Multi rail PSU's durdy Power Supplies 1 December 30, 2007 09:16 AM
-12v Rail and Poor Performance kcksteve Troubleshooting 11 September 9, 2007 08:08 PM
