Old August 11, 2009, 07:25 PM
ToXic's Avatar
Default Actual consumtion
When running a calculator it told me a 750W would be best, so how much power is it actually using? because im adding a Nvidia card to do PhysX work to the equation, witch recommends a 350W supply.
Some kind of pathetic Apple convert
17" Macbook Pro (early 2011 model)
2.2Ghz i7-2720QM | 8GB Corsair DDR3 1333Mhz | 750gb Toshiba HDD | ATI 6750M 1GB
Old August 11, 2009, 07:29 PM
Padding your post count are we?
Old August 11, 2009, 07:32 PM
ToXic's Avatar
no, im wondering how much power im going to need, i honestly dont want to have any messups with my supply. i could care less about my count as i just use this place as a information hub, and not some sort of get more posts game.
Old August 11, 2009, 07:34 PM
Arinoth's Avatar
Could you not ask this in one of your many other threads that are related either to a third GPU with PhysX or your 2-3 gpu threads?
Old August 11, 2009, 07:38 PM
ToXic's Avatar
its a power supply question though, not a GPU question so its more fitting here is it not?
Old August 11, 2009, 07:40 PM
ChuckleBrother's Avatar
1) You gave no information about what cards you have, what cards you plan to have and what other stuff you might be running in your system. I don't care if it's in your sig, all relevant data should be in the OP
2) From what I see you create a fair number of threads, and this topic has been covered, at very very great length.
"...you play a mean banjo"
Old August 11, 2009, 08:38 PM
b1lk1's Avatar
1. Bunch of grumpy buggers. If responding to a thread is gonna piss you off why bother?
2. I believe a forum's purpose it to post threads with questions looking for information.
To the OP, no worries, it'll be fine.
MY HEATWARE
Old August 11, 2009, 08:48 PM
ToXic's Avatar
Thanks for a real response, ans not just a flame.
Old August 11, 2009, 08:50 PM
...You haven't even said what other card you want to add! How can you garner any information here. We need to know what you will be powering and what exactly your configuration is, for all we know your nvidia card could be a 295, we need SPECS dude, seriously.
Old August 11, 2009, 08:53 PM
Sushi Warrior's Avatar
I'd guess 380W idle consumption and 700W+ load, but I couldn't say for sure....
