<~----> max dc voltage in north america? - Hardware Canucks
Old August 6, 2007, 08:47 PM
Default max dc voltage in north america?
oki here's the deal im in the market of getting a new psu in excess of 1000watt but how much voltage can the normal lines outpout in voltage?? is 230volt oki? or is it too much for the lines in montreal ? and if so what's the maximum so i could base my next psu on this info..
no sig at the moment :P
Old August 6, 2007, 11:19 PM
North America is regulated to 110-120 volts (w/ a few exceptions, like washer/dryer outlets).
I don't see why you'd want to go w/ 220-240 volts ...
Old August 7, 2007, 01:36 AM
well i guess ill go dual psu's then...
Old August 7, 2007, 03:23 AM
Delavan's Avatar
Frosty,
All regular wall outlets are on a 120V (already mentionned by Jmac), 15Amps breaker. (w/ a few exceptions, like washer/dryer outlets)...thanks Jmac!
Anything else you want can be done (by a Qualified electrician only).
Example...you use a paper shreader (office type) on the 240 V...you'll need a special dedicated circuit with a special prong/wall outlet combination (to avoid any "mishaps") and it can be done....by a qualified dude only. If you own a house, feasible...if you rent an appartment forget about it all.
i5 2500K @ 4.5GHz / NH-U12P / P8P67 DELUXE / 8GB Corsair Vengeance Arctic White 1.35V 1600 / 2 x N560GTX Ti Twin FROZR II OC in SLI (8823 3Dmarks11 P-score)/ Corsair Performance Pro 128GB SSD
Old August 7, 2007, 04:47 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
What you really need to look into is the amperage of your breaker or fuse. Even though the breaker is rated to 15A, this rating is for PEAK consumption and not CONTINUOUS consumption. A 15A breaker can safely handle between 12-13A of sustained draw.
When you factor that all together (13A @ 120V) you get a peak safely sustained power draw of 1560W. And personally, I can't think of ANY system you could put together which consumes that much power.
Even a 1000W PSU which has an efficiency of 80% running at 100% load would still "only" draw 1200W from the wall.
You have to remember, if you buy a 1000W PSU it does not draw 1000W all the time but draws whatever power (plus factoring in efficiency) is demanded of it by the components.
Old August 12, 2007, 07:47 PM
maybe i missunderstood the amp and voltage thing on psu oO so i should look at how much amp to be able to handle 2 hd2900 + dual core cpu etc... ????? 80A is it enough
Old August 12, 2007, 08:46 PM
what are on earth are you doing that even requires 1000w!
Over Voltage a35599 Overclocking, Tweaking and Benchmarking 6 February 26, 2008 09:21 PM
Overclocking question (Voltage) Wasza Overclocking, Tweaking and Benchmarking 2 January 22, 2008 10:28 AM
What is Stock Voltage? mattydies Video Cards 10 October 19, 2007 09:01 PM
Voltage and PSU monitoring software BALISTX Power Supplies 10 September 5, 2007 05:05 PM
Worst Comapanies in America 2007 Competition: Consumerist Babrbarossa Off Topic 4 March 20, 2007 02:07 PM
