Old July 29, 2009, 06:56 AM
BIGFREAK's Avatar
Default PC Power and Cooling 750 or Corsair TX750 ???
Hi guys need to upgrade my PS and I have it down to the
PC Power and cooling 750W Quad
Newegg.ca - PC Power & Cooling S75CF 750W EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Active PFC Power Supply - Power Supplies
or
Corsair TX750
Newegg.ca - CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply - Power Supplies
Please help me out or great forums full of Hardware Geeks :)
Thanks
Old July 29, 2009, 07:05 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
I would say that in almost every aspect they are pretty much the same even though the PCP&C unit will be slightly louder.
Old July 29, 2009, 07:12 AM
BIGFREAK's Avatar
so the legendary PC Power and cooling has meet its match...
I have read that the voltage is a little tighter on the PC Power.
I know you have done the tests. :) :)
I want 2 things
1. Not Modular
2. A Single FAT 12V rail.
Help me out :)
Thank you.
Old July 29, 2009, 07:36 AM
SKYMTL's Avatar
You're looking at two PSUs that meet your requirements. In the end, I would personally go with the one that is less expensive and doesn't come in red. That's just be though since I don't like the look of a red PSU. ;)
Old July 29, 2009, 07:44 AM
nige's Avatar
my pcp&c 750 has been working flawlessly since i built my machine in sept. it is definitely audible, but not super loud
Gigabyte GA-MA790FX-DS5 - AMD 1090T B.E. - Palit 4850 - 4x2GB Muskin 6400 - PC P&C Quad 750w - 500G WD Black - 500G + 250G WD Caviar - Xonar D2 - Win7 - Antec Sonata - Z680
Macbook Pro 13" - Intel CD2 2.53ghz - 4GB DDR3 - OSX 10.6.1
Old July 29, 2009, 07:45 AM
joeperson's Avatar
I'd go for the one that uses something bigger (and hopefully quieter) than an 80mm fan.
Q6600 3.0GHZ (9x333) stockV | ATI 5850 | OCZ Platinum 4GB PC2-6400 DDR2 5.4.4.15 1.9V | Silverstone Raven RV01 | Gigabyte EP45-DS3R
Corsair Professional HX750W | Windows 7 | Crossbow mounted Xigmatek HDT-S1283 | LG W2242TQ-BF 22" | Samsung 2253BW 22"
Old July 29, 2009, 08:10 AM
I would go with the Corsair. Buy from ncix.com & price match with bestdirect.ca.
Old July 29, 2009, 08:31 AM
BobbyLou's Avatar
pcpNC > cors-fair
Old July 29, 2009, 08:50 AM
burebista's Avatar
If your budget fits you can take a look at Antec TP New 750. IMO is better than your both choices. If not stick with Corsair.
Old July 29, 2009, 09:02 AM
sswilson's Avatar
Either choice would be fine. I have one of each and they've both served me well. As far as the noise levels on the PCP&C goes, the 80mm fan might scare you away, but it's not overly loud IMO.
Why are Tx750 recommended so much over Silencer 750? sheepdogexpress Power Supplies 13 March 22, 2009 07:42 PM
how far can the corsair TX750 go exactly? squilliam Power Supplies 12 December 17, 2008 10:27 AM
