Old July 29, 2009, 09:33 AM
BIGFREAK's Avatar
sweet well Corsair it is then :)
Thanks for all the Help guys.
mmmm good active forums are a god send.
Old July 29, 2009, 10:29 AM
Jake_HT's Avatar
Depending on your case design too the PCP&C unit may be a better choice because of the rear fan....
http://jakeht.deviantart.com/
Old July 29, 2009, 11:00 AM
BIGFREAK's Avatar
The Corsair should be fine. My Case is the Original Antec P180 so the PS mount is raised up with a hole for the bottom mount fan type.
Old July 30, 2009, 10:14 AM
dukelod's Avatar
My PCP&C 750 has been a work horse, very happy with it.
Intel Core i7 930
Thermalright Ultra 120 Extreme Black Ultra Kaze 3000rpm
EVGA X58 3Way SLI A1
Corsair XMs3 6GB DDR3 1600
Windows 7 Ultimate 64bit
Antec Truepower Quattro 1200 OC Version
XFX GTX295
XFX GTX295
Coolermaster HAF 932
Logitech G15 Keyboard
Logitech G5 Mouse
X-Fi XtemeGamer
Old July 31, 2009, 02:27 PM
FtGF's Avatar
Well I hope you have enough money for your PSU after fixing your car........................
Fight the Good Fight
Old August 5, 2009, 05:11 AM
OmegaRED's Avatar
Nothing but good things to say about the PC Power & Cooling 750. I don't see how the Corsair could possibly be quieter because the PC is practically silent enough that it's hard to tell if it's running. When I was choosing a PSU last year I narrowed it down to these two and found that this one was generally considered to be better quality at high loads than the Corsair but that was then and I'd go with whichever is cheaper at this point.
E-Penis Specs:
Coolermaster Cosmos II \\ Intel i5 2500K@4.8ghz \\ Gigabyte PA67 UD7\\ MSI Twin Frozr GTX 680 SLI \\Corsair Vengeance 8GB LP \\ Seasonic Platinum 1000W \\ X-Fi Titanium HD \\ OCZ Vertez 3 120GB \\ RAID 0 Seagate Barracuda 1TB SATA6G 64MB \\ Samsung 27" 3D LED Monitor \\ Logitech G5 \\ Logitech G-15 Keyboard \\ Logitech Z-5500 \\ Sennheiser 595 \\ Windows 7 x64
Old August 5, 2009, 09:20 PM
rjbarker's Avatar
Both good PSU's....
Firestrike Extreme: 21.452
MARK 11: 32.530
Old August 6, 2009, 11:52 PM
Originally Posted by burebista View Post
If your budget fits you can take a look at Antec TP New 750. IMO is better than your both choices. If not stick with Corsair.
'Cept it's got 4 +12v Rails. Anyway, I recommend getting the TX750w, Fantastic Power Supply, I find you cant really beat corsair on the quality of the power supply's, and they're made by seasonic, so, that's also a plus. Also, that's what all the cool kids are doing these days.
  #19 (permalink)
Old August 7, 2009, 12:04 AM
CanadaRox's Avatar
Just buy the cheaper between the two (be sure to use PriceCanada.com and get the lowest price for both, then pricematch at NCIX.com). They are both extremely good PSUs and meet what you want in a PSU so you will be very happy with either. I personally own the PCP&C Silencer 750W and I find it quiet, but they will both suit your needs just fine.
Project: Black and White
  #20 (permalink)
Old August 7, 2009, 12:23 AM
burebista's Avatar
Originally Posted by GT_Forthelulz View Post
'[...] and they're made by seasonic, so, that's also a plus.
Not all of them. TX750 is a CWT PSH.
TP New is a Seasonic...
Why are Tx750 recommended so much over Silencer 750? sheepdogexpress Power Supplies 13 March 22, 2009 07:42 PM
how far can the corsair TX750 go exactly? squilliam Power Supplies 12 December 17, 2008 11:27 AM
