Old July 19, 2009, 03:30 PM
Default Will corsair 750TX work if not connected to a PC
Hi
I just bought a 750TX for my system, I plan to take the power supply to my home country to install it in my desktop but now I don't have any test systems I can use
I tried to power up the PSU while its not connected to a PC and it didnt start up, no sound no nothing, is this normal or do they not start up when not connected?
Thanks
Old July 19, 2009, 03:36 PM
shayan288's Avatar
you have to jump it i believe or sumthing liek that. Take a paper clip and unbend it into a straight line
and bend it so one end goes into the 4 pinhole and the other end goes into the sixth (on the 24 pin mobo connector). then switch it on.
PS the 4th and 6th pins one of them is green the other is black.
The 288
Q9550 E0 stepping @ 4Ghz
Gigabyte EP45 UD3P
G.Skill pc2 8500 1066mhz RAM
Western Digital 250gb
Antec 1200
XFX HD5970
Steelseries Xai Laser Mouse
Windows 7 Ultimate x64
Old July 19, 2009, 04:10 PM
gingerbee's Avatar
. do a google search. sorry don't want to get in any trouble ( just not sure if hot-wiring a power supply is ok here or not)
Old July 19, 2009, 04:28 PM
I will buy a power supply tester.
I just want to make sure it didnt power on because its not connected
thanks for the help
Old July 19, 2009, 04:36 PM
sswilson's Avatar
It's a fairly simple task... jumper the green wire with one of the black ones. Some PSUs require a load of some form (like a fan or two on the molex) as well.
Old July 19, 2009, 04:40 PM
heres a guide with pics Power Supply Jumping Guide
http://valid.canardpc.com/show_oc.php?id=932179
"Be so good at what you do that you cant be ignored"
Old July 19, 2009, 04:44 PM
Shadowmeph's Avatar
thats what I do and it worked
Old July 19, 2009, 06:31 PM
Thanks for the help
I really dont want to mess with the PSU like that, its brand new and it dont want to risk it
will this work Canada Computers - Power Supplies > Accessories : Thermaltake A2358 Power Supply Tester.
Old July 19, 2009, 06:48 PM
Shadowmeph's Avatar
Originally Posted by fire_storm View Post
Thanks for the help
you could always just grab a switch hook one wire into the green and the other into the red then turn it on its exactly the same thing
Old July 19, 2009, 06:52 PM
sswilson's Avatar
Thanks for the help
I'm sure it'll work fine. Just make sure when you pick it up that it has a connector for the 20/24 pin. The description sounds like it does, but the image doesn't show it.
Cooling Mushkin Redlines - Corsair Dominator Cooler work? chouchou RAM 9 November 29, 2008 03:07 PM
Will This Work? Infiniti Video Cards 2 July 21, 2008 11:54 AM
Will This Work? stormkiller22 Troubleshooting 9 March 5, 2008 06:02 PM
Real Car Gauges connected to PC via USB for Racing Sim Supergrover Press Releases & Tech News 0 May 30, 2007 05:15 PM
