Old July 4, 2009, 04:47 PM
Originally Posted by MasonStormatHardwareCanuc View Post
I have two systems that use dual PSUs. It isn't absolutely necessary; as others have pointed out above, you could just use one good PSU. But I can tell you that your system will never be quiet if you're running 4 powerful GPUs off of one PSU (I mean modern GPUs that require two power connectors each, not the weaker ones that have only one connection).
For example, I have a Folding@home rig that hosts two 8800GTXs and two 9800GX2s. My Enermax Galaxy EVO 1250 can handle all of that, but it's as loud as a vacuum cleaner. So instead, I'm using two quality, high-power PSUs, splitting the load between them. In this manner, neither is being called upon to deliver even 50% of its rated capacity; and so both PSUs remain blissfully quiet. And this quietude is worth it to me to go to the trouble of dual PSUs.
By the way, as far as I know, there are only about 3 cases on the market that are designed to house two PSUs...otherwise you'll need an open rig of some sort. The Nzxt Khaos and the Antec P190 both come with a cable that starts both PSUs at the same time; otherwise you could buy a dual-PSU adaptor cable from PerformancePCs.com (it was less than $10, if I remember).
Powersupplies are only loud when they are being overused and some power supplies get louder when more of a load are on them.
Old July 4, 2009, 05:20 PM
geokilla's Avatar
Um Canada Computers has the OCZ StealthXStream 500W for $30, not the GameXStream.
As for running it like that, you can but I'd advise against it. Where are you going to put the 2nd PSU? Plus your case would have to be open all the time and imo, it's pretty dangerous to do that.
Old July 4, 2009, 05:54 PM
Chilly's Avatar
I have to disagree here, most *good* power supplies get loud because of heat triggering the fan they use to jump from 20% to 80%(and then 100% if your system/PSU get really hot). Same reason why some people think reference coolers on some ATi/nVidia cards are loud, because the default fan profiles provided by companies are never as smooth as they should be stock.
What I'm trying to say is this, a loud PSU does not mean its being overused, but an overused PSU will always be loud.
[WTB] Power supplies needed yamawho Buy/Sell & Trade 4 February 24, 2009 01:35 PM
Can I use two Power Supplies? Infiniti Power Supplies 19 January 22, 2009 09:44 AM
[WTB] Power supplies [multiple or single] n-sanity Buy/Sell & Trade 0 January 16, 2009 04:36 PM
Modular power supplies - what do I really need etc Nodscene Power Supplies 3 December 11, 2007 05:49 AM
Power Supplies enaberif Power Supplies 1 January 25, 2007 12:17 AM
