-   -   Is this safe to use? (http://www.hardwarecanucks.com/forum/power-supplies/19503-safe-use.html)
napier July 2, 2009 12:20 PM
8-pin EPS-12v to 2x 8pin EPS-12v Y cable - 6" - Sleeved Products Model: CB-EPS8-Y [CB-EPS8-Y] : Performance-PCs.com, ... sleeve it and they will come
My new setup requires 2 8pins I only have one, but im not sure how safe this is?
sswilson July 2, 2009 01:42 PM
I wouldn't use one myself, but the "safeness" of it is going to depend greatly on what PSU you have and what card you intend to run.
Jackquelegs July 2, 2009 02:08 PM
If you're intending to use it on a GPU, sorry you cannot use this. This is 8pin EPS12v, not PCI-e 8pin.
However like SSwilson said, the safety of these adapters greatly vary by your setup. It'll help if we knew what they were
Chilly July 2, 2009 02:41 PM
He's planning on using it on a workstation build.
Sorry I didn't get back to your PM sooner, yes the 8-pin Y cable will work just fine with the PSU your using and any motherboard that requires it.
napier July 2, 2009 06:19 PM
Sorry I didnt post the specifics ,but I am using it for a dual processor workstation build.
specs:
nvidia quadro fx3700
dual xeon e5520
corsair 850tx power supply
