Old June 20, 2009, 02:53 AM
fefox's Avatar
Default 110v vs 220v Comparison
Has anyone done a comparison on the bigger wattage power supplies and figured out the power savings and difference in heat output running them on 220v vs 110v??
It would seem to me as pc power supplies get into the 1000w range you could start saving a bit of $$$ on power. if the near future has larger than 1500w, 220v is going to be a sure thing...
Old June 20, 2009, 03:43 AM
Perineum's Avatar
I'm kinda hoping that computers get more effecient.... but very interesting train of thought anyway
Old June 20, 2009, 05:37 AM
yamawho's Avatar
I wouldn't lose any sleep over it ...
Not many will purchase a 1000watt psu's even among geeks, who is crazy enough to need one
Just a lot of hype ...
Old June 20, 2009, 08:24 AM
stoanee's Avatar
In my limited knowledge of power I believe that the power draw will be the same 110 vs 220v. There will not be any savings made on the basis of voltage alone, any efficiencies will have to be from the physical construction of the psu. 220v is capable of delivering more amperage, as is 480v, with all related systems built increasingly more robust to handle the higher amperage.
heatware
Old June 20, 2009, 08:31 AM
JD JD is online now
When efficiency testing is done, 220V always fairs better from everything I've seen. However it's not a significant amount where you'd save hundreds of dollars.
If you want to save power, don't overclock and leave all the power management stuff enabled so that it down-clocks when idle.
Old June 20, 2009, 08:57 AM
Perineum's Avatar
With wattage being volts x amps it means that the "draw" from the wall in amps will be half at 220 vs 110.
Easier to design something to handle 10 amps of current than 20 and a lot less heat should be involved, I think.
It sounds like you're equating voltage as being tied to amperage but the two values are completely seperate.
So anyway, if you have a system that eats 1100 Watts of power from the wall at 110 volts that'll be 10 amps of current. Likewise, 1100 watts of power from the wall at 220 would be 5 amps of current.
Sorry if I misunderstood what you said. I don't have an overly fantastic understanding about how it all works but I *think* I know the basics....
Old June 20, 2009, 09:36 AM
burebista's Avatar
Efficiency at 220V is ~2-3% more that equivalent power draw at 110V. No big deal to me.
When you draw 1kW from outlet saving 20-30W looks like a joke to me.
Old June 20, 2009, 11:35 AM
fefox's Avatar
I know on paper you get some gains, was just wondering if anyone has done real world tests....
Im thinking of a PC based FOLDING machine that runs 24/7 @ 100% duty, you have to be saving some $$$ @ 220v
ok so I want to buy a power BIG power supply that will be running full out 24/7 its silly not to run it @ 220v
I think it would be a interesting fact to post its cost savings at that voltage and if the manufacturer is saying its %80 eff is it 80% at 110v or 220v?
I have a feeling that if it does both they will use the 220v numbers to make it look better.
I just figured someone must have done this but maybe im wrong, everyone is tweaking the hell out of their machines trying to get more speed for less, trying to cool them...
220v means more eff so less $$$ and less heat..
hahaha maybe there just needs to be a PSUID program before tweaking your PS or getting a high end one will become important ;)
Old June 20, 2009, 12:48 PM
burebista's Avatar
Of course that someone did: SPCR. For CM SilentPro 700 for example. There are other PSU's too in PSU section on SPCR.
Wrong, if you buy a 1.5kW PSU for a 500W load you may end paying more on electricity than choosing a 750-800W PSU for a 500W load.
Old June 20, 2009, 01:11 PM
fefox's Avatar
Thanks burebista thats exactly what I wanted to see.
looks like on that one power supply you need to run less than 50% of its rated load to get the 83% eff...
that 700w PS needs to have a 250-300w draw for it to be in the zone anything over or under that it drops off big time.
I was under the impression that the eff window was allot higher than that...
I still will need a big power supply im planning to draw about 1200w @ full duty.
What price comparison site do you use the most? Dazmode Off Topic 15 May 28, 2009 10:55 AM
Price Comparison Jon_di2 Suggestions & Feedback 13 May 9, 2009 02:15 PM
Thermal paste comparison Technokat Overclocking, Tweaking and Benchmarking 3 April 7, 2009 08:12 PM
Heat sink comparison Bones Air Cooling 11 March 27, 2009 05:07 PM
AA comparison of ATI and NV in games walkingdog Video Cards 9 September 10, 2008 04:20 PM
