Old May 24, 2009, 03:00 PM
Default Help!, PSU issue...
Hello
I recently bought en Enermax Revolutions 85+ 950w PSU. Heres the problem; I installed it about 2 weeks ago and it worked like a charm. I just opened up the case and removed a fan controller, in doing so i decided to re-route some wires. After the job was complete I thought all was well but when I plugged in the PSU and hit the switch on the PSU to turn it on the computer started up on its own, without me hitting the main power button. All the fans started wailing at full RPM's and within a couple seconds the system shut down again and would not turn on. I tried unplugging and plugging back in but to the same scenario. I have made sure that all the components are plugged in.
Any help would be appreciated as this is really starting to annoy me as it worked just a couple hours ago.
Thanks
My Rig:
Gigabyte 890GX / AMD Phenom II x6 1055 / Crucial Ballistix Tracer 4GB / EVGA GTX470 SC+ / Stock Cooling (Yet) / Corsair TX850 / Corsair Nova 128GB SSD / Antec 902/ Windows 7 PRO 64 bit/ 24" Acer LED Monitor
Old May 24, 2009, 03:25 PM
Supergrover's Avatar
Dbl check all the connections you touched, if it still is dead , unhook everything but a fan for some load and jump the PSU.
Old May 25, 2009, 05:20 AM
Soultribunal's Avatar
On every PSU I've owned, when the On switch is selected in the back of the PSU, after plugging in the supply all my fans come on for a brief second and then power down.
That to me is normal operation.
For you, I'd check and make sure the MB cpu connectors are good, and if nothing else do what Supergrover suggested and power in only the bare essentials to see if it works or not.
Regards,
ST
www.realhardwarereviews.com
Old May 25, 2009, 12:37 PM
Cowboy's Avatar
There's always the option of calling tech support or the place where you bought it to exchange for another one.
Issue with Paypal hohohee Off Topic 37 April 22, 2009 02:55 PM
Issue :[ DavidDemise Troubleshooting 56 March 22, 2009 07:04 AM
PSU Cylcing Issue ChuckleBrother Troubleshooting 17 June 20, 2008 11:04 PM
PriceMatch 20% Issue! e_1337 Off Topic 1 March 16, 2008 03:58 PM
need PSU suggestions, current PSU isnt cutting it Rains Power Supplies 13 December 11, 2007 08:53 AM
