Old May 21, 2009, 11:42 AM
MrBear09's Avatar
Default Corsair 850TX
just wondering if the corsair 850TX can run this setup:
Core i7 920 OC'd to 3.6-3.8
DFI LP UT X58 T3eH8
6GB 1600 Corsair ram (possibly add another 6 later)
Up to 6 Seagate 1TB 7200.12 Hard drives
GTX 285 in SLI
Just wanna know if I should end up going with something bigger or not.
Thanks
Old May 21, 2009, 12:07 PM
Soultribunal's Avatar
I don't see why not, that has a 70A 12v Rail.
That should suffice, but It would probably crap out for Tri-SLI.
ST
www.realhardwarereviews.com
Old May 21, 2009, 12:25 PM
rjbarker's Avatar
You'll be fine....defintely go to Corsair 1kW if your entertaining Tri Sli...
I had 2 x 280's OC'd running on a PC P&C 750W for awhile..the 280's draw more power than the 285's....with that said it was on a E8400 at 4.1 Ghz as aposed to an I7.
Firestrike Extreme: 21.452
MARK 11: 32.530
Old May 21, 2009, 01:10 PM
MrBear09's Avatar
Thanks, I haven't really even considered going for Tri SLI because when I actually need the extra power, something newer and alot better will be out :p
Corsair HX1000W bangegat Power Supplies 3 May 21, 2009 05:44 AM
how far can the corsair TX750 go exactly? squilliam Power Supplies 12 December 17, 2008 11:27 AM
Fs: Corsair Hx620 vinister Buy/Sell & Trade 10 April 23, 2008 11:51 AM
Corsair TX750W Cptn Vortex Power Supplies 5 November 4, 2007 10:55 AM
