Old May 15, 2009, 05:55 AM
Soultribunal's Avatar
Default CoolerMaster PSU's
Anyone have any experience with these?
SKYMTL, if you're out there, do you know off hand who their OEM is?
I've been considering one , but am a little sketchy without a little more knowledge.
Regards,
ST
www.realhardwarereviews.com
Old May 15, 2009, 06:11 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
OEMs for Cooler Master vary from one category to the next. Generally, their higher-end is made by Enhance, mid-tier by Acbel and lower end by Hipro or Seventeam.
Old May 15, 2009, 06:18 AM
Hmmmmm, thats a mixed bag for sure.
Perhaps I'll avoid their lower end for now then.
I was looking at grabbing a 500W , because it was cheaper than most out there.
Thanks for the info,
ST
Old May 15, 2009, 08:54 AM
Babrbarossa's Avatar
Cooler Master eXtreme Power 550W Power Supply | PSU
I put one of these in a build about 8 months ago- after about 5 months, the fan bearing started to go (it's noisy for the first minute or so after startup). No other experience than that though.
Old May 15, 2009, 09:15 AM
THanks Bab....I might just stick to what I know then.
I find a few reviews here and there, but not enough for my confidence.
Might go the VX450 , and hope the Corsair is up to the challange of powering a 140W Processor.
ST
Old May 15, 2009, 09:42 AM
I think the xtreme power is their lower end, and probably a bit more sketchy.
The "real power" and "ultimate" is the better stuff but seems to be priced the same as corsair, pc power and cooling etc but seems to be reviewed as inferior ... so you may as well go with what you know.
Having said that I have a Coolermaster IGreen 600w that runs 24/7, its a few years old and has had no issues.
Old May 15, 2009, 09:46 AM
sswilson's Avatar
Didn't NCIX just add a whole hockeysock worth of decent mid-priced/lower wattage PSUs to their lineup?
Old May 15, 2009, 10:12 AM
I'll take a look Wilson, I Am aiming for the lowest Reasonable capacity PSU , to shave costs a little.
@ Snoose, yeah which is wierd to me. Considering at least for the higher end units being Enermax (As SKY was kind enough to let me know) that OEM is sharded with a few vendors.
I dunno, I think the Corsair should pull it off, that or get a PC Cooling one.
ST
Old May 16, 2009, 08:35 PM
jcmaz's Avatar
I have a Coolermaster eXtreme power 600W. Its OK for normal usage, ie. budget builds w/ good video cards, but for high end build, go for something else.
About the sound, it sort of loud, but bearable. (for me atleast)
-Plato
Old May 16, 2009, 08:38 PM
SKYMTL's Avatar
The CM UCP is their high end stuff now.
Coolermaster Cosmos S sswilson Cases 90 October 19, 2009 11:51 AM
coolermaster v8 issue SanjoTHEBanjo Air Cooling 6 May 7, 2009 04:53 AM
a pox on coolermaster and myself as well.... rob123 Cases 6 December 15, 2008 06:01 AM
Coolermaster CM 690 lanken123 Cases 7 October 5, 2008 09:56 PM
Coolermaster CM 690 kcksteve Cases 29 January 1, 2008 10:53 AM
