Old April 9, 2009, 05:42 PM
Default PSU question...
Hello,
This is prolly a silly question that has been asked before but I am just curious. Lets say a have a Corsair 1000HX running an Intel quad core and 280GTX, would the power supply draw 1000w from the wall or only what it needs to power the rig??.
Thank you
My Rig:
Gigabyte 890GX / AMD Phenom II x6 1055 / Crucial Ballistix Tracer 4GB / EVGA GTX470 SC+ / Stock Cooling (Yet) / Corsair TX850 / Corsair Nova 128GB SSD / Antec 902/ Windows 7 PRO 64 bit/ 24" Acer LED Monitor
Old April 9, 2009, 06:10 PM
gingerbee's Avatar
only what it needs
Old April 9, 2009, 06:12 PM
aviduser's Avatar
HowStuffWorks "How PC Power Supplies Work"
Only uses what it needs. (beat me to it)
I5 4670K 4.4ghz - Gtx 780 Amp - 2x4 Corsair Vengeance - MSI z87-g43 - Tx 850w - Asus pbq278q
Old April 9, 2009, 08:24 PM
JD JD is online now
I think really old PSUs would draw full out power all the time, but yeah anything recent only draws what the components need.
Still that doesn't mean you should run a 1KW PSU if your PC really doesn't need it as the efficiency would most likely be lower at low power loads, so you'd be better off with a suitable PSU and enough load to get it running at it's peak efficiency. Though of course this probably won't save you tons of money on electricity, but if you're concerned about it then yes it will.
PSU question DavidDemise Power Supplies 3 March 22, 2009 12:44 AM
Question for SKYMTL !!!! (or other PSU gods) Delavan Power Supplies 21 February 6, 2009 04:17 AM
Looking for a new PSU ChuckleBrother Power Supplies 18 October 17, 2008 06:26 PM
basic(?) psu question - dual rail combined ratings ccm001 Power Supplies 7 March 26, 2008 04:58 AM
need PSU suggestions, current PSU isnt cutting it Rains Power Supplies 13 December 11, 2007 08:53 AM
