Old April 1, 2009, 12:16 AM
kyle_L's Avatar
Default squealing psu
so under different loads my psu like to make different noises. when idle no noise when folding on 4870x2 no noise but when casual gaming only using 30-60% CPU and gpu it makes loud a squealing noise. anyone know what this is and how to fix it, no warranty on psu. and this only started after i turned it upside down for my new case.
Gotta Love Timmies Coffee.
Old April 1, 2009, 12:17 AM
its not the PSU.
Its your GPU.
And its normal.
Old April 1, 2009, 12:18 AM
Jake_HT's Avatar
Probably video card capacitors.. mine do it while I'm folding. It's annoying, however that's all it is. No worries.
http://jakeht.deviantart.com/
Old April 1, 2009, 09:50 AM
KaptCrunch's Avatar
just poor harmonics engineering on the power drive circuits not enough buffering
Old April 1, 2009, 11:38 AM
3 of 7's Avatar
If the fan on the psu is thermally controlled it may be going south.. If you can get at the computer with the side off when it's making noise reach into the psu fan with a pencil or something and press on the middle of the fan to stop it and see if the noise changes.
