Old March 21, 2009, 07:19 PM
CTA's Avatar
CTA CTA is offline
Default low budget psu
i tried to check sparkle 300 ish watts at ncix but no available...
any suggestion? i only can find low budget reliable psu for 24/7 is 400cx
Old March 21, 2009, 08:36 PM
Silvgearx's Avatar
BP350.ATX12V VERSION 2.01 350 WATT PSUDUAL +12V - DirectCanada
$35 350Watt
Canada Computers - : OCZ StealthXStream 500W Power Supply - Active PFC, 120mm Fan (OCZ500SXS).
$40 after MIR 500watts
Old March 21, 2009, 09:10 PM
CTA's Avatar
CTA CTA is offline
i never heard of bp350 before... how good it is?
SS-350ET for 34 at BD which is nice deal as bp350... i think seasonic is better... i hope they must be realiable as corsair...
Old March 22, 2009, 03:50 PM
Silvgearx's Avatar
BP350 is made by antec. Its the new budget series! I have used to have 2 antec earthwatts 500, and they both are good and reliable PSU and quiet
The Cheap EA series are really well build. It weights at least 5-8lbs
Old March 22, 2009, 04:21 PM
yamawho's Avatar
Antec doesn't make psu's, they farm them out.
I purchased a few Seasonic SS-350ET's from ncix a few weeks ago, both are working.
Old March 27, 2009, 06:11 AM
Newegg.ca - SILVERSTONE ST400 400W ATX 12V 2.2 Power Supply - Power Supplies
$39.99
Old March 27, 2009, 11:57 AM
CTA's Avatar
CTA CTA is offline
i already bought bp350 because deal of ss-350et is gone...
Old March 28, 2009, 03:30 AM
burebista's Avatar
Basiq Power are FSP inside. EA380 is Seasonic, older EA430/500 are Seasonic, new EA430/500/650 are Delta.
$500 Parts Budget BALISTX New Builds 15 October 26, 2008 06:19 AM
Need some advice for a low budget PC ebdoradz CPU's and Motherboards 14 December 14, 2007 08:52 PM
My new budget-ish pc kcksteve CPU's and Motherboards 21 November 27, 2007 12:24 PM
Budget system Wiked CPU's and Motherboards 15 October 13, 2007 02:49 AM
Budget HTPC BALISTX HTPC Systems & Software 4 May 28, 2007 08:16 AM
