Old March 19, 2009, 09:47 AM
Nxt38's Avatar
Default PSU suggestion for a HP?
okay so I got this HP pc last year for 700 dollars...
I thought it was a good bang for the buck but turns out the psu is only 380w
I want to upgrade the psu soon and I plan to make a graphic card upgrade in the near futrue (HD4850 most likely)
what would max wattage would you recommend with my system?
Also any suggestion on product?
specs and hardware:
Q6700
HD3850
DDR2 4g
2x 500G 7200 SATA HD
DVD-R
memory card reader, network card, etc
Old March 19, 2009, 02:34 PM
JD JD is offline
Assuming it's a standard ATX PSU, I'd go with a Corsair 550W or 650W.
Old March 20, 2009, 07:11 AM
Mr. Gruntsworthy's Avatar
HP=bad customization/upgradeability
My old P4 HP machine didn't accept standard ATX PSUs. I hope they've changed that, for your sake.
MAIN RIG:
Case: CoolerMaster HAF 932
CPU : Intel i7-5820K 6-core @ 3.3GHz
RAM : 32GB DDR4 2400MHz (G.SKILL Ripjaws)
HDD : Main: 240GB SSD SATA2 (Intel) Storage: 3TB SATA2 (WD Green) Backup: 500GB External USB (Hitatchi)
GFX : Gigabyte GTX 970 4GB
PSU : 750W Corsair Modular PSU
MoBo: Asus X99-A
View : Acer H213H 21.5" @ 1920 x 1080 + random 4:3 monitor
Level/Game Designer, Programmer
http://mikeseguin.webs.com/
I run Durham 3D Printing, an online 3D Print shop!
Old March 22, 2009, 10:47 AM
Nxt38's Avatar
frankly I have no idea.
the tower is medium size, so I assume that it fits.
... or I hope... really for my sake
Old March 22, 2009, 11:19 AM
Nxt38's Avatar
Looks like the power supplies are standard ATX.
what should I expect to spend on the power supply and can anyone point at a specific model for me to look at? :D
Old March 22, 2009, 11:24 AM
Maybe go with a PC Power Silencer 610W or something similar from Corsair. You won't need any more than 650W (For reference, my machine runs off a 610W PC Power Silencer)
MAIN RIG:
MoBo: Asus X99-A
Old March 22, 2009, 11:26 AM
Customizing a HP just isn't worth the money.
Lack of airflow, lack of room and all sorts of other headaches.
Generally a lot of psu that you will try may not work depending on how hp has their board, psu, or power switched hooked up.
Old March 22, 2009, 11:36 AM
You'll have to look for a PSU typically marked "HP upgrade" etc; unless you KNOW what connectors your system will require and if the PSU has it.
Provided the connectors are correct I suggest the Corsair CX400 - I have one running a similar system with a 4850 already.
Old March 23, 2009, 12:25 AM
Nxt38's Avatar
basically I will just have to find the spec for installed PSU and find a new psu with all the connectors that the old one had?
Old March 23, 2009, 07:44 AM
JD JD is offline
If you post the model number, or even open up the case and take a bunch of pictures, we should be able to determine if a ATX PSU would fit and work.
board suggestion ? Jim CPU's and Motherboards 4 March 11, 2009 11:00 AM
board suggestion ? Jim CPU's and Motherboards 0 March 11, 2009 09:48 AM
Need suggestion for OC romeodelanoche Overclocking, Tweaking and Benchmarking 11 November 6, 2008 08:48 AM
Suggestion qwerty Suggestions & Feedback 5 October 16, 2007 02:22 PM
ram suggestion skyline510 RAM 9 September 15, 2007 09:55 AM
