Old March 23, 2009, 09:26 AM
Nxt38's Avatar
DPS-350AB-8 is the model number.. 3.3" x 5.8" x 5.5" is the demensions
Old March 23, 2009, 11:46 AM
JD JD is offline
HP 350W POWER SUPPLY <br>5188-2859 (DPS-350AB-8A )
Looks like a standard ATX PSU to me. Though it does have far shorter cables.
Have you opened up the case yet? I'd make sure you can fit a GPU in there and that you have space for all the additional cables a "proper" PSU will have.
If it's a tight setup, then you might have to get something like a Silverstone Strider PSU w/ short modular cables (they sell it as an accessory).
Old March 24, 2009, 06:16 AM
aviduser's Avatar
Never had a problem upgrading the PSU in my old HP. Mind you it was fairly new.
Most ATX Psu's will have the option of a 20/24 pin power connector, or 4/8 pin Mobo connector. The only other thing you need to worry about is the mounting holes, but they're pretty standard these days.
Personally you might as well go for a quality psu, that you could put into your next rig. Corsair, PC Power and Cooling, or even OCZ seem to be good choices.
If your on a tight budget Sparkle Psu's seem to get good reviews and are pretty cheap.
HAF-Full
-Phenom II 940 @ 3.8 ghz
- Sapphire 5870 890/1220
- 4 ghz g.skill
- Corsair tx850w
Old March 26, 2009, 10:07 PM
Nxt38's Avatar
Thanks for the help guys
board suggestion ? Jim CPU's and Motherboards 4 March 11, 2009 11:00 AM
board suggestion ? Jim CPU's and Motherboards 0 March 11, 2009 09:48 AM
Need suggestion for OC romeodelanoche Overclocking, Tweaking and Benchmarking 11 November 6, 2008 07:48 AM
Suggestion qwerty Suggestions & Feedback 5 October 16, 2007 02:22 PM
ram suggestion skyline510 RAM 9 September 15, 2007 09:55 AM
