Old February 22, 2009, 12:28 AM
Phobia's Avatar
Default replacing ocz gamexstream 700w fan
Hello all, I have been wanting to replace the fan in my gamexstream for a while now. Its running as my home server's psu, and its too loud, and i don't want the LED's in it. I bought a noctua p12 off of Vortex, and I wanted to install it. However, once I took the psu apart, it seems the fan is connected by only a red and black wire, no yellow. Can I just cut the wires from both, and solder them on, and leave the yellow wire alone? the stock fan isn't connected by a 3 prong connector, and I cannot seem to pull it off, so it would seem that the only way to put a new one on is by cutting the wires, and attaching a new fan on like that.
I also don't mind going and buying a fan that will fit (no yellow wires), but it has to be silent!
Old February 22, 2009, 12:51 AM
Infiniti's Avatar
You can cut off the yellow wire, most of the time, it's just useless. All you need is the black and red wire, and make sure you get it right, or you'll fry your fan.
Old February 22, 2009, 12:32 PM
Phobia's Avatar
awsome. Thank you, its done, and seems to be working *knock on wood*
Old February 22, 2009, 01:47 PM
SugarJ's Avatar
FYI, the yellow wire on a 3 pin fan is the RPM sensor.
Old February 22, 2009, 02:48 PM
Phobia's Avatar
ahh, thanks. I was wondering what it was. Oh well, the fan on the psu didn't have one, so I assume its ok without it. I changed my mind, and used an sflex instead of the noctua. I didn't want to wreck the noctua when ncix doesn't have any more in stock right now..
Old February 22, 2009, 02:55 PM
So what was the end result? Do you find a noise difference? Is the PSU still running cool enough?
RIG #1 - Intel E8400 // TRU-X 120 w noctua NF-P12 // GA-X38-DQ6 // GTX285 OC // 8g Ram OCZ Fatal1ty PC8500 // X-Fi Elite Pro sound // z-5500 speakers // OCZ 850w Gamer XTream PSU // WD Raptor 150g // Seagate 1Tb // 2xSeagate 500g ex// Logitec G-15 keyboard // Vista Ultimate 64bit
RIG #2 - AMD64 3500+ // Asus A8N-E // 8800GTS 512 OC // Enermax Liberty SLI 500W Modular PSU // WD Caviar 250g
Old February 22, 2009, 04:20 PM
Phobia's Avatar
the noise is significantly quieter. I don't know the temps of the psu.. I need to find that out :P However, from sticking my hand near the psu, and the exhaust air, it feels about the same as before.
[FS] BFG 8800GTX OC2 & 500 GB hard drive Spitfire Buy/Sell & Trade 18 July 31, 2009 12:09 PM
[WTB] 450-700w psu werth Buy/Sell & Trade 5 February 18, 2009 04:49 PM
ocz gamexstream 600w Defiant Power Supplies 5 November 29, 2008 06:58 PM
OCZ GameXStream 700W vs Mushkin 650W thatguy Power Supplies 4 October 7, 2008 07:48 PM
OCZ releases GameXStream 1010W Babrbarossa Press Releases & Tech News 12 March 13, 2007 05:29 PM
