Old February 14, 2009, 09:08 AM
Default powering xtc memory cooler
well been a long time lurker on the forums, great info!
but i wanted to overclock my whole system, and i purchased the xtc cooler yesterday.
after clocking my q6700 to 2.9ghz, i notced that the mem cooler fans were running slow, if i put my finger on the fan it stops. so to me its like not getting enuff voltage/current to the fan....i pluged it into my motherboard into the 3 pin fan(xfx 680i sli)....just thinnking any way to get more voltage to it? looked in the bios for info didnt find anything related...kinda a newb to the bios but i understand how to oc things...
worst case scenario was gonna hardwire onto a 4 pin molex and plug into the psu.
Old February 14, 2009, 09:22 AM
sswilson's Avatar
What specific header are you plugging it into? Some motherboards allow you to set fan speed in bios for CPU/NB headers, but system headers are generally 100%.
Old February 14, 2009, 09:31 AM
http://images.tigerdirect.com/SkuIma...450-9102-c.JPG
very bottom right beside the yellow header
http://img.hexus.net/v2/internationa...tery_large.jpg
in this pic, on the bottom left corner
when i first start the computer, it does put 100% power, but then after boot scren it dies down..
Old February 14, 2009, 09:37 AM
sswilson's Avatar
Did you try the one in the center? (Right beside the memory).
It does sound like it's being managed by the bios. You can also try turning off any references to allowing the bios to control temps.
SKYMTL's Avatar
HardwareCanuck Review Editor
I will tell you, that is VERY odd. Did the cooler come with a 3-pin to Molex adaptor? If so, you can plug it directly into your PSU.
Old February 14, 2009, 09:42 AM
the one on the far right is used by my cpu fan, the one on the bottom center is used by my front case fan.
na it didnt come with a molex conector, may have to get one or modify one..at first it all powered up fine, but then i noticed behind the grid that the fans were moving slowly..
i got a 750 ultra psu....duno what the hell is wrong...it still gets power, the leds still glow, its just at full speed...
Old February 14, 2009, 06:28 PM
Soultribunal's Avatar
Tigerdirect has 3 - 4 pin Adaptors by either ultra or Cables to go for like 2.99 I think. I picked one up for my Dominator Fan.
No need to modify when pocket change will suffice!
Regards,
ST
www.realhardwarereviews.com
Old February 17, 2009, 01:58 PM
thx for the info guys, but be4 i was gonan buy the adapter, then thought lets try flashing the bios...did it be4 i clocked my system, but did it again and seemed to fix the problem...weird..
WinTV PVR-150 & Remote | EverCool Memory Cooler | 1394 Card & FrontX Adapter pcgeezer Buy/Sell & Trade 69 March 28, 2009 10:23 AM
PC not powering up yamawho Troubleshooting 5 January 14, 2009 03:20 PM
How to make you own Memory Cooler (RAM) Boldeagle Guides & How-to's 24 July 31, 2008 11:32 PM
PC not powering up neyjunior Troubleshooting 6 June 7, 2007 01:17 PM
OCZ Technology Unveils the XTC (Xtreme Thermal Convection) Memory Cooler Gav RAM 8 December 14, 2006 07:10 PM
