Old January 12, 2009, 04:21 PM
Cptn Vortex's Avatar
Default Need a 12V Powersupply
I need a 12V powersupply just to power a few fans.... and hopefully rather small... Any ideas? basically, I killed the fan header on my Xbox 360's board.... Right now I am using a jumped 450W antec, but I think it is a little ugly and overkill...
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old January 12, 2009, 04:29 PM
donimo's Avatar
just get one of those radio shack specials and adapt it, how many mA you need?
I might have a few...
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
Old January 12, 2009, 04:32 PM
3 of 7's Avatar
I'm using a small one that plugs into a wall socket to run a 120mm fan for circulation around my woodstove, I dunno what it was off of ( phone charger?) but it puts out 12v @ 2 amps so it should run a few...
I think any 9v or 12 one should work well enuff.
Old January 12, 2009, 04:33 PM
SugarJ's Avatar
Exactly what I was going to suggest. I'm sure you could pick up a cheap 12v or even 9v adapter, solder it to a header or something.
Old January 12, 2009, 05:01 PM
Hmm looked around the house and I only have a 19V and 5V...
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
Watercooling:
Old January 12, 2009, 05:21 PM
vinister's Avatar
local electronics supply store should be able to get you something decent.
Mobo: DFI 790X-M2R
Proc: AMD PHENOM X3 720
Ram: OCZ Platinum 2X 2GB @ 1066
VIDEO: 3 x Visiontek HD3870
Old January 12, 2009, 05:24 PM
3 of 7's Avatar
The 19 should keep the xbox cool!!
Old January 12, 2009, 05:28 PM
SugarJ's Avatar
Hook up a Delta to the 5V!
Old January 12, 2009, 05:48 PM
Yea, That COULD work....hehe
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
Watercooling:
Small Powersupply Cptn Vortex Cases 5 November 6, 2007 06:02 PM
