Old December 29, 2008, 09:45 AM
Default quick nooby question
okay, so cables that come on a psu:
20/24pin atx,sata power, molex power, pci-e 6/8pin....
now whats that other cable that connects to the mobo again?
that is usually near the cpu seat...mine is top left corner...
asking because im looking to buy an extension for it .
CPU:E8400 @ 3.8GHZ -->Zalman 9700NT HSF
GPU:XFX 5870 1GB
HDD:150GB Raptor,WD500GB,WD1TB BLACK
MOBO:Asus Striker 2 Formula
RAM:OCZ HPC REAPER 4GB 1066mhz pc2-8500 (5-5-5-15)@2.2v
PSU:CORSAIR 750W
CASE:Silvertstone TJ07
SOUND:Auzentech X-Fi Prelude
Keyboard:Logitech G15 V2
Mouse:Razer DeathAdder
Case Cooling:2x92mm exhaust,2x120mm exhaust, 2x120mm Ultra Kaze(3000RPM)intake.
Running:Win7 64-bit Ultimate
F@H PPD:46957
Old December 29, 2008, 09:49 AM
Shadowmeph's Avatar
I think that it would depend on the Motherboard but on the few mother boards I have had there also is a 4 pin plugin
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old December 29, 2008, 09:54 AM
nah , this cable is on all psu's its mandatory for mobo
GPU:XFX 5870 1GB
PSU:CORSAIR 750W
F@H PPD:46957
Old December 29, 2008, 10:01 AM
12v EPS 4/8 Pin
Old December 29, 2008, 10:02 AM
any idea where i could get extension for it?
GPU:XFX 5870 1GB
PSU:CORSAIR 750W
F@H PPD:46957
Old December 29, 2008, 10:15 AM
Exmortis's Avatar
Check DirectCanada/NCIX and search on cables, my cooler master case came with an 8 pin EPS extension, so they do exist. I also use it, allowes me to route that cable back behind the mobo tray and up to the top of the tray where a small hole is cut to allow it to pass through to the mobo itself.
Exmortis's System
Corsair 600T White
Asus P8Z68 Deluxe /Gen3
Intel i7-2600K w/Corsair H100
8GB Gskill DDR31600 cl7
MSI Lightning HD797 Lighting
OCZ Revo 3 240GB
OZC Vertex 3 240GB
WD Velocirapter 600GB
LG DVD burner
LG BluRay Burner
Sound Blaster XFi Titanium PCIe
Windows 7x64 Prem
Asus VE24/VE27/VE24
Logitech Z-5450 5.1 speakers
Corsair AX850 Gold PSU
Corsair K90 Keyboard
Logitech G5 Mouse
Old December 29, 2008, 11:04 AM
morphine's Avatar
I was looking for one last year and couldn't find anything locally. I eventually ordered from Performance PCs.
Here are the ones they carry:
8-Pin (EPS12V) Extension Cable 12 Inches - Sleeved [8-PIN-EXT] : Performance-PCs.com, ... sleeve it and they will come
8-Pin (EPS12V) to 4+4-Pin EPS12/ATX Extension Cable 12 Inches - Sleeved Products Model: 8-PIN-4+4-PIN-EXT [8-PIN-4+4-PIN-EXT] : Performance-PCs.com, ... sleeve it and they will come
Old December 29, 2008, 11:06 AM
NCIX.com - Buy Startech 8" Eps 8 Pin Power Extension Cable - EPS8EXT In Canada.
Old December 29, 2008, 11:35 AM
8 EPS 8 PIN POWER ........... EXTENSION CABLE - DirectCanada Same one I believe
Quick question Zippoh New Builds 10 December 2, 2008 08:48 PM
Quick Question /b/ derrXIII Video Cards 2 August 12, 2008 02:55 PM
quick question... omgwtf O/S's, Drivers & General Software 14 July 22, 2008 05:31 PM
Quick question Nodscene Power Supplies 2 July 7, 2008 11:27 AM
Quick Question. Khronos Display Units 2 January 7, 2008 01:16 PM
