Old December 19, 2008, 09:37 AM
Question 1KW Power Supply Needed....
I need a 1KW power supply that has the following:
two 2x3-pin and two 2x4-pin connectors for ATI CrossFireX™ technology in dual mode
Old December 19, 2008, 09:39 AM
CMetaphor's Avatar
Quadfather
The Corsair TX750 can handle that, it has 4x 6/8-pin PCIe connectors. Best PSU for the money IMHO.
Old December 19, 2008, 09:43 AM
I need a 1KW power supply, not less....
Old December 19, 2008, 09:46 AM
CMetaphor's Avatar
Quadfather
Maybe you should explain Why you need it? For Crossfire, even with two 4870X2's, the TX750 should handle it.
Old December 19, 2008, 09:50 AM
From Sapphire's site:
1K Watt with two 2x3-pin and two 2x4-pin connectors for ATI CrossFireX™ technology in dual mode
Old December 19, 2008, 10:23 AM
CMetaphor's Avatar
Quadfather
Um, yeah. That's called an "estimate". Check out the signatures of some of our members here. I think I've even seen a Tri-Sli system running off of the same Corsair TX750 that I suggested. Otherwise, if you're dead-set on getting a 1Kw power supply. The HX1000 from Corsair is an excellent option.
Old December 19, 2008, 11:14 AM
matsta31's Avatar
It seems mister Lauzon like to buy only the best and does not like suggestion, so If you absolutely want a 1Kw, then go for the corsair as suggested. you can never go wrong with corsair PSU, they are reliable and have good pricing.
Sold hardware again.....
Currently using WHS hardware....
Old December 19, 2008, 06:41 PM
rjbarker's Avatar
Yep...he's back...Mr. Mannerless......
Firestrike Extreme: 21.452
MARK 11: 32.530
Old December 19, 2008, 07:16 PM
MpG's Avatar
MpG MpG is offline
I can vouch for the Ultra X3 1000W, although it not widely available and a little pricier than others. Good performance, entirely modular, single 12V rail, and the fan stays pretty quiet until it's pushed hard. Also very sleeking looking, with its titanium finish and black flex cables.
Old December 19, 2008, 08:46 PM
rjbarker's Avatar
The I have
Corsair HX1000W Power Supply Review
MARK 11: 32.530
What's the best power supply for under $150? Jamz Power Supplies 18 April 12, 2008 03:31 PM
Is my power supply enough? Shepherd Power Supplies 3 August 19, 2007 09:32 PM
