Old May 16, 2007, 07:36 PM
BALISTX's Avatar
Default PSU Help
I have heard that the Enhance ENP-5150GH 500W is the same as the Silverstone Element ST50EF-PLUS 500W that SKYMTL reviewed. Can anyone verify this for me and from what I can tell if this is the case the only difference is the the ST50EF-PLUS has sleeved cables and is a retail box where the ENP-5150GH does not have sleeved cables and is an OEM package.
Enhance ENP-5150GH 500W - $73.44
Silverstone Element ST50EF-PLUS 500W - $90.93
Also here are the specs on the my rig that I will be using this PSU on, I think it should be enough.
AMD Opeteron 144
DFI LANParty UT Ultra-D
2GB OCZ EL Plats PC3200
EVGA 7900 GS KO 256
WD 80GB 7200rpm
SB X-Fi Xtreme Audio
LG 16X DVD-ROM
HP 16X DVD±RW
2 CCFL
3 x 120mm case fans
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old May 16, 2007, 08:02 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
The price difference is not worth it. I would not sacrifice the 3-year Silverstone warranty for $17.
Old May 16, 2007, 08:06 PM
BALISTX's Avatar
That's a very good point. Thanks for the advice SKYMTL.
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
